Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 04-12-2006, 02:31 AM
ta99wb ta99wb is offline
I was wondering if the 93 caprice had the lt1 if not is it carbed?
Old 04-12-2006, 02:54 AM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
Re: 1993 5.7
Niether. If you have a 1993 w/350, the engine's a TBI L05. There's a good chance that it's a 9C1 with that 350, although in that model year some were offered to the public with that engine, I've come to understand.
If it really is a 350, the SPID label in the trunk will have L05 and the VIN code for the engine will be 7. If it's a 305, it will be L03 and E, respectively.
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
Old 04-12-2006, 03:15 AM
Re: 1993 5.7
Its a 350... Its my buddies car and he was wanting a cold air intake and he told me that the air filter was ontop of the engine, so thought is had a carb. I havent looked at the engine myself but i thought it had an lt1
Old 04-12-2006, 08:34 AM
Blue Bowtie's Avatar
Registered Offender
Re: 1993 5.7
It wouldn't have had an LT1 or L99 until 1994. IIRC, 1988 was the last year for domestics to have a carb.
FWIW, a CAI isn't going to help much on an L05. The big restriction on those is the stock "swirlie" heads and restrictive exhaust. The next worst problem is the cam profile. Once you have solved those, the TBI220 is next, along with a better intake tract and reprogramming.
Actually, reprogramming would help right away, since you can enable Highway Fuel and Spark Modes and trim up the timing tables a little better. If memory serves me, the TCC lockup points in that late TBI factory programming were pretty weak, too.
Old 04-12-2006, 02:18 PM
1986Z28's Avatar
1986Z28 1986Z28 is offline
Has a Camaro
Send a message via MSN to 1986Z28
Re: 1993 5.7
no its not the lt1 its a tbi 350 (LO5)
Formerly Blownalcoholboy
1986 Z28, 400ci SBC, Twin borg warner billet S467 turbos, Reid case powerglide, Moser 9". Holley EFI, Boost Leash. 950RWHP on pump gas, 1200rwhp on race gas (22 psi)
Best ET 1/4: 8.35 @ 170mph (275 drag radial)
Best ET 1/8: 5.44 @ 132mph (275 drag radial)
Best 60': 1.31 on the back tires (275 drag radial)
AF User Rules/Guidelines
http://www.automotiveforums.com/vbul...uidelines.html
