Old 04-12-2006, 01:10 AM
frehol frehol is offline
Bad idler arm
Hi,
How serious is a bad idler arm? I can move it up and down some 6mm and steering feels no good.
Is it any risk is breaks off so I loose the right wheel steering?
Need to know if I can drive ītill I get a new idler...
/Freddy
Old 04-12-2006, 05:07 AM
muddog321 muddog321 is offline
AF -Advisor
Re: Bad idler arm
Most Blazers with higher mileage all get the sloppy idler arm and doubt it will break off - wait 6mm is like 1/4" so thats about normal if you tested with only the pass side wheel off the ground and did the side to side wiggle test. If your steering is really bad I would look at the complete front end and all the tie rods and the lower ball joints first. If a 2wd the center link assembly wears out too and also the pitman arm (2wd only).
Old 04-12-2006, 10:05 PM
swalt's Avatar
swalt swalt is offline
Re: Bad idler arm
Keep in mind that when checking the idler arm and wiggling the tire, the control arms need to be loaded (supported) by stands. I have always thought mine had slop and the dealer provided me a GM tech document stating how it should be tested....namely loading up the control arms and testing then.
