Old 04-12-2006, 01:09 AM
chevycentric chevycentric is offline
Need some help with my 4.3
I Hope someone can help me out here. I have a 94' Blazer 2wd with the 4.3 W code. Its running rough at idle, sluggish acceleration , occasional bad cat converter smell, and using alot of fuel. I just replace the coil, plugs, wires, and distrubutor. The mechanic told me it was the efcm(his phrase) and the part would be $350-500. The guy at the parts store told me this part doesn't exist. Any insights?
Old 04-12-2006, 04:59 AM
muddog321 muddog321 is offline
AF -Advisor
Re: Need some help with my 4.3
Sounds like the classic leaking CPI (injection) and nut kit (hoses) under the upper intake. Search the many posts on this and the fix is in the FAQ section.
Old 04-12-2006, 07:47 PM
ZL1power69's Avatar
ZL1power69 ZL1power69 is offline
GM S-Series Mod
pull the imtv off the top of the intake manifold (under the vortec cover) and look down in there for leaks. if u have one, u will see clean areas. clean on drivers side=bad nut kit, clean on pass side=bad fuel regulator.
2000 Chevy Blazer ZR2
Performance Mods: Numerous
Suspension Mods: Some, but not enough
Exterior Mods: Just Right
1987 Buick Turbo T Dark Red
Low 11 sec sleeper
.030 4.1 block, PT6262E, & other odds and ends....
My Cardomain
Old 04-12-2006, 10:04 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Yip, CPI injector and nut kit.
Also you will need to clean your EGR valve.
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 04-12-2006, 11:50 PM
dmbrisket 51's Avatar
dmbrisket 51 dmbrisket 51 is offline
Send a message via AIM to dmbrisket 51
electronicly controlled fuel meater, big long bullshit line used on customers for saying 'nut kit'
Old 04-13-2006, 12:00 AM
BlazerLT's Avatar
AF -Advisor
You mean fuel pressure regulator.
Old 04-13-2006, 12:19 AM
yeah, wow, wtf was i thinking
Old 04-13-2006, 09:33 AM
ZL1power69's Avatar
GM S-Series Mod
figures, after i replaced my cpi and nut kit, they started selling the fuel regulator by itself .
Low 11 sec sleeper
My Cardomain
Old 04-13-2006, 11:59 AM
BlazerLT's Avatar
AF -Advisor
Don't worry, you did the right thing by replacing it all.
