Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 04-11-2006, 10:48 PM
slavejay slavejay is offline
lowering ride
has anybody lowered a 80-90 caprice, if so, how do you like it? does it drive differently? suggestions, do's and don'ts???? any remarks appreciated.... sorry for so many questions lately, just wanna play with my ride for summer time
Old 04-12-2006, 08:10 AM
Blue Bowtie's Avatar
Registered Offender
Re: lowering ride
The only proper way to lower the vehicle is with new spindles. Lowering springs will require camber adjustment that will be near the limits of the provided adjustment range. Even at that, bump-steer may become an issue with the swingarms positioned closer to the top end of the range.
The rear is fairly straightforward, requiring only a different rate and free height spring, and the required adjustment of the pinion angle. You'll need to adjust the lower control arms and use an angle gauge after the spring swap, but that's about all.
If you simply swap in lowering springs as so many others have done, the handling will be out the window, and driveshaft/pinion angle will be very ugly on hard launches. You'll find out the first time you have to pick pieces of driveshaft and U-joint out of your swiss-cheesed plastic fuel tank. Then again, the wheel hop should warn you of that ahead of time.
Old 04-12-2006, 11:20 AM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
Re: lowering ride
Actually those have steel fuel tanks!
But yeah, I was going to bring those two points up last night, then fell asleep first.
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
Old 04-12-2006, 01:18 PM
1986Z28's Avatar
1986Z28 1986Z28 is offline
Has a Camaro
Send a message via MSN to 1986Z28
Re: lowering ride
just keep the 20"+ wheels away from it
Formerly Blownalcoholboy
1986 Z28, 400ci SBC, Twin borg warner billet S467 turbos, Reid case powerglide, Moser 9". Holley EFI, Boost Leash. 950RWHP on pump gas, 1200rwhp on race gas (22 psi)
Best ET 1/4: 8.35 @ 170mph (275 drag radial)
Best ET 1/8: 5.44 @ 132mph (275 drag radial)
Best 60': 1.31 on the back tires (275 drag radial)
AF User Rules/Guidelines
http://www.automotiveforums.com/vbul...uidelines.html
Old 04-12-2006, 03:01 PM
88capriceclassic 88capriceclassic is offline
Re: lowering ride
and crushed velvet swiveling seats away too haha
Old 04-13-2006, 01:00 PM
1986Z28's Avatar
Has a Camaro
Re: lowering ride
dont forget the tv's in every empty space of the car
Old 04-13-2006, 02:26 PM
Re: lowering ride
can't forget the navigation system either.... or the record player in the trunk
Old 04-13-2006, 05:17 PM
1986Z28's Avatar
Has a Camaro
Re: lowering ride
lol or the curb feelers and the gold trim and the candy apple red paint, oh dear i dont feel so good
Old 04-13-2006, 05:32 PM
GreyGoose006 GreyGoose006 is offline
Red face Re: lowering ride
You forgot the fuzzy dice... that LIGHT UP!
Old 04-13-2006, 05:41 PM
Re: lowering ride
i think we all made a funny.hehehe
Old 04-13-2006, 06:14 PM
silicon212's Avatar
Confoundingly Lucid
Re: lowering ride
Or the fart can exhaust tips... or the wheel spacers that stick the wheels out into the air ...
Old 04-13-2006, 07:17 PM
ddax's Avatar
ddax ddax is offline
Re: lowering ride
...or do all the above then post a pic and get laughed out of the forum!
Dave
