Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 04-11-2006, 09:53 PM
Eclipse4ever's Avatar
Eclipse4ever Eclipse4ever is offline
Turbo Diagnostic
How do I figure out if the turbo is burning oil. I saw that in the intercooler pipe there was a little bit of what it looked like oil. I am not sure but I wanted to check too see if my turbo is really burning oil. It has less then 4000 miles on it but I already saw a crack inside the exhaust turbine. It was acrack on the side but it was visible enough. Also, I checked and there was no shaft play but I need upper intercooler pipes, where the BOV mounts to, and I cant find any anywhere. Is it possible to buy the flange that the BOV is atached to seperatly, because I can fabricate it on the pipe.
Thanks guys.
1997 Eclipse GSX
Old 04-11-2006, 11:11 PM
ez1286's Avatar
ez1286 ez1286 is offline
Send a message via AIM to ez1286
Re: Turbo Diagnostic
Do you have an oil catch can on? Otherwise you can get oil in the intake and through the turbo.
95 GSX:FMIC, 6-bolt, evo 3 16g, 2600 act clutch, 1g bov (crushed), and a 3" turbo back exhaust, dsmlink, dks 272 cams, wideband 02, Coming soon 2.3L Stroker, 1mm oversized valves, crower sprigs. 91 TSI AWD auto, gm 3.5 maf, maft, fmic, emanage, profec e-01, 3" turbo bk exhaust +more little stuff.
http://www.ratemydsm.com/member/ez1286/?member=ez1286
Old 04-11-2006, 11:30 PM
blk_srt's Avatar
blk_srt blk_srt is offline
Send a message via AIM to blk_srt Send a message via MSN to blk_srt
you can get the flange on ebay. as far as the oil it could be your pcv or your turbo.
2004 Flame Red SRT-4
|Audiobahn 1200Q|Rockford 602s|Jensen flip out dvd|
Mods:
Old 04-12-2006, 12:42 AM
So if the turbo is leaking oil, does it means that seals are gone bad or I have to rebuild the whole thing ? I just saw that there was a trail of oil from the turbo through the pipes back to the intake. It has like 4300 miles on it so i really dont tink its the turbo.
You guys think that an oil catch can will do the trick?
1997 Eclipse GSX
