Go Back   Automotive Forums Car Chat > Pontiac > Trans Sport
Old 04-11-2006, 08:04 PM
guido0136 guido0136 is offline
replacement of front/side turn signal lights (1993)
Does any one know how to replace the front side turn signals. Not the ones under the front bumber, but the one that wrap around sides. Both of mine are out, and I can't, for the life of me, find as easy way to change these.
Any easy way?
Thanks.
Old 04-11-2006, 09:40 PM
GregA's Avatar
GregA GregA is offline
Re: replacement of front/side turn signal lights (1993)
Any easy way?
Thanks.
Give the following page a look (about half-way down).
http://www.autozone.com/servlet/UiBr...3d801ef317.jsp
Take Care,
Greg A.
2001 Chevy Venture w/some "enhancements" ~ 105K Miles (Dec. 2010)
1992 Jeep Cherokee Laredo, 4.0L, Automatic ~ 155K Miles (Dec 2010)
Old 04-12-2006, 06:36 AM
paul.v
Guest
Posts: n/a
Hmmm, I only see rear lights on that link...I'm sure its in there somewhere but its pretty easy..There are 2 wing nuts on your headlight assembly. Remove these , pop out the headlites & you'll have easy access to the signal lenses...1 nut .
I'm scrapping a 93 if you need parts...new PCM..
Paul
Old 04-12-2006, 07:23 AM
Okay, sounds easy enough, I'll give it a try.
Thanks.
Old 04-13-2006, 12:30 AM
GregA's Avatar
I just remembered that I have some pictures of that area for my 2001 Venture. I don't know if they are similar to the 1993, but I thought I would give you the link anyway.
Turn Signal Assembly
Take Care,
Greg A.
Old 04-19-2006, 05:58 PM
Thank you all for your help. I was able to change these this past weekend. I believe this takes much longer than it should, but I'm not a car builder.
Thanks.
