Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 04-11-2006, 06:55 PM
david-b's Avatar
david-b david-b is offline
Dave is THAT guy
Question Rotor installation
I finally ordered some rotors.
How hard are they to install? I just had new ones put on last spring on the rear and had the front ones re-surfaced. So the bolts have to be pretty loose still. Is there a writeup anywhere that would give me an idea on what I'm doing? Thanks!
2013 Chevy Sonic 1LZ
75 Monte Carlo
01 Pontiac Grand Am SE - RIP
Old 04-11-2006, 07:02 PM
ned032002's Avatar
ned032002 ned032002 is offline
Re: Rotor installation
Have you ever changed Rotors? Well if it's anything like the 1st gen then you'll need a 14mm socket and a breaker bar to get the caliper bolts loose but I doubt you'll have that much trouble. There not too bad though just jack the car up and take off the tire, then take the bolts out of the caliper and push the caliper to the side. Then just take the rotor off, sometimes they'll stick so just hit the rotor with a mallet and it'll come off. Then replace in reverse order. GL
Old 04-11-2006, 08:32 PM
1992eclipseGS 1992eclipseGS is offline
don't u have to bleed the brakes?
1998 RS
5 speed, Stock front bumper w/molded urethane lip, Blitz side skirts, Bomex rear, JSP Carbon Fiber hood. Halo Projection Headlights, Escort radar detector, Turbo style spoiler, 1,200 watt sound system with 2 dual 12 subs, 20% executive tint, 17" sport rims, Custom built 2 1/2 Exhaust, OBX 4-1 Header, CAI, KYB GR-2 struts, Sprint lowering springs.
Old 04-11-2006, 08:40 PM
ez1286's Avatar
ez1286 ez1286 is offline
Send a message via AIM to ez1286
You should but you don't have to if you don't take off any brake lines.
95 GSX:FMIC, 6-bolt, evo 3 16g, 2600 act clutch, 1g bov (crushed), and a 3" turbo back exhaust, dsmlink, dks 272 cams, wideband 02, Coming soon 2.3L Stroker, 1mm oversized valves, crower sprigs. 91 TSI AWD auto, gm 3.5 maf, maft, fmic, emanage, profec e-01, 3" turbo bk exhaust +more little stuff.
http://www.ratemydsm.com/member/ez1286/?member=ez1286
Old 04-11-2006, 08:51 PM
ned032002's Avatar
I didn't think you did either unless you remove the brake lines.
Old 04-11-2006, 09:12 PM
blk_srt's Avatar
blk_srt blk_srt is offline
Send a message via AIM to blk_srt Send a message via MSN to blk_srt
you don't have to bleed them unless you take off a brake line since it is a sealed hydraulic system. there are 2 bolts holding the caliper on and 2 holding the bracket on and after that they should just slide off. key word is should. Most of the time they are stuck and you can do 1 of 2 things, 1 since you have new rotors you can just hit the old ones with a hammer to break them loose or 2 there is a little threaded hole in the rotor that you can thread a small bolt into to pop them off of the hub
2004 Flame Red SRT-4
|Audiobahn 1200Q|Rockford 602s|Jensen flip out dvd|
Mods:
Old 04-11-2006, 11:07 PM
david-b's Avatar
Dave is THAT guy
I've done brakes... those are easy. Never done rotors though. I did some searching, and it seems easy enough.
You don't bleed unless you take off the brake lines from the calipers.
75 Monte Carlo
Old 04-11-2006, 11:13 PM
rock0134 rock0134 is offline
Send a message via AIM to rock0134 Send a message via Yahoo to rock0134
If you have trouble getting the capiper bolts to break loose or the bolts for the caliper bracket, put the car on blocks of wood and use the hydraulic jack to jack up and use as leverage on the ratchet it works really good...
its wierd how you have to screw a bolt into it to release like a lever to get the rotor to pop off
Does anyone know how to put in a wheel stud from here?
SOLD
'97 GSX
EvoIII 16g, FMIC shortroute piping, FIC 850's, DSMLink V2.5, 3" turboback, mbc, Walbro 190 rewired, autometer boost gauge, Tokico shocks/springs -2", Motegi MR7 18" hyper black wheels
'05 blacked out f150 FX4
Old 04-11-2006, 11:19 PM
blk_srt's Avatar
also make sure to clean the rotors with brake cleaner before you install them
Mods:
Old 04-11-2006, 11:31 PM
david-b's Avatar
Dave is THAT guy
Is there bolts on the back that hold the rotor on? How many are we looking at here?
75 Monte Carlo
Old 04-12-2006, 12:09 AM
ez1286's Avatar
No they are probably rusted on. Use 2 large bolts (the biggest ones that fit in the caliper mount holes) Put the bolt through and put a nut on the inside closest to the rotor, tighten the bolt while you hold nut as it tightens it will push into the rotor and push it off. Do it once loosen and turn the rotor, keep going until it comes off.
Old 04-12-2006, 12:22 AM
george536's Avatar
george536 george536 is offline
If you know how to do brakes, then im pretty sure you can see how easy it is once the caliper is off, that you just slide out the rotor. unbolting the tire should be the hardest part. lol
-1997 Eclipse Spyder GST |Stock|
-1990 Eclipse GSX
|ACL Main & Rod Race Bearings|Balance Shafts Removed|ARP Head Studs|Cometic HG|FP 20g TDO6H|EPROM Chipped (stutter box 5k, fuel comp.)|PTE 680cc inj.|Walbro 255 HP Fuel Pump|Autoteq FPR|SAFC 2|FMIC|2g MAF|Dejon Tool Hard Pipe|Greddy Type S|MBC at 17PSI|Ported 2g Exhaust Manifold|02 Housing w/ Tial 38mm WG|Full 3inch Exhaust w/ Y-pipe Cutout|Fidanza Flywheel|ACT 2100|4 Bolt LSD Rear|Poly Mounts|KYB AGX Suspension|Roll Bar|
Old 04-12-2006, 12:24 AM
ez1286's Avatar
Maybe if they're brand new but if they've been on a while it wont be easy at all.
Old 04-12-2006, 12:27 AM
blk_srt's Avatar
My opnion is that since you are replacing the rotors anyway to get them off you can tap them with a hammer with no problems
Mods:
Old 04-12-2006, 01:05 AM
david-b's Avatar
Dave is THAT guy
Cool. I won't get them in for about a week and a half yet, so Ill keep this all in mind. Like I said, I got brake work done last year, so everything should be pretty easy to take off. The front rotors have been machined twice in 2 years, so they need to be replaced. They're slightly warped again, so they gone.
I'll post pics when I get them on. Should be sweet with the Enkeis and cross drilled and slotted rotors, and im repainting my calipers again (red of course). The rotors as zinc plated too so they wont show the rust. This should look great when I'm done.
75 Monte Carlo
