Old 04-11-2006, 05:49 PM
DaMoNe6969's Avatar
DaMoNe6969 DaMoNe6969 is offline
engine feedback
havin problems installing a simple stereo in my new car.. Its a 95' BMW 325i..
as soon as I hook up the RCA's to the amp, I get engine feedback through my back factory speakers.
The battery of my car is in the trunk, so I have the amp wired directly to the battery, + and - so they arent no where near the RCA's..
Would grounding the Amp directly to the battery cause this??
The amp is powering a 10" sub and is not connected to the factory rear speakers
1991 Camaro Z28
Old 04-11-2006, 10:07 PM
PaulD PaulD is offline
Audio Guy
Send a message via AIM to PaulD Send a message via Yahoo to PaulD
Re: engine feedback
more than likely, you're RCA's are running close to a noisy source
Old 04-12-2006, 01:58 PM
dave92cherokee's Avatar
dave92cherokee dave92cherokee is offline
Re: engine feedback
At some car stereo shops you can get a RCA ground loop isolator which hooks inline with the rca cables and has a grounding wire that you just connect to a good chassis ground behind the radio and will eliminate almost all noise.
Old 04-12-2006, 08:33 PM
CBFryman's Avatar
CBFryman CBFryman is offline
Banned
Send a message via AIM to CBFryman Send a message via Yahoo to CBFryman
Re: engine feedback
ground loop isolator and alternator wine are different problems. get the RCA's away from any noisy source.
If that doesnt work, the only otherthing yo ucan do with out ocmprimising SQ/ouput isto find a diode and place it inline with the Power Wire. This will filter out all non DC current to the amp.
Old 04-13-2006, 06:04 PM
Audio Guy
Re: engine feedback
Not really, alternator noise is often inducted into a system with ground loop problems. This is when the reference ground for the signals in the headunit are at a different potential than the reference ground for the signals in the next stereo unit down the "RCA" chain. A ground loop isolator is a transformer on the RCA lines that breaks the physical connection.
Old 05-17-2006, 01:01 AM
kram5527 kram5527 is offline
Re: engine feedback
Keep the RCA's away from power lines that source current. By transformer action, the alternator ripple can be induced in the RCA lines even if the power line is not tightly magnetically coupled to the RCA's.
Old 05-17-2006, 08:53 PM
pimprolla112's Avatar
pimprolla112 pimprolla112 is offline
Send a message via AIM to pimprolla112 Send a message via MSN to pimprolla112
Re: engine feedback
^ do what. There is a simple answer and it was already posted hes most likely getting interference from within the cars chassis. Whether its a ground, power wire, signal wire for something else.
How do you magnetically couple the RCA's to the power wire.
I did install a ground loop isolator on my older car for the speaker amp, it had horrible feedback, fixed the problem slightly still had some feedback but the way this one was it sounded like the damn car was reving with the amp to an exact tune. It was horrible. It was a combination bad ground, bad rca path and not enough experience. My first install.
Cant remember who posted it but if you see it give yourself credit
Don't ever look at cars as just imports or domestics. Just because a car is made in a certain country doesn't mean that it is anything like another car from that country. An example of this is Mitsubishi reliability, just because they are Japanese doesn't mean that they are as reliable as a Honda or Toyota.
Cardomain
