Go Back   Automotive Forums Car Chat > Toyota > 4Runner/GX470
Old 04-11-2006, 05:35 PM
gapboi210 gapboi210 is offline
Odd jerk when coming to a stop
Is this normal? when I come to a stop, the suspension feels like something is shifting or moving. It does this right before I come to a stop. BTW it is a 4x4.
Old 04-11-2006, 11:33 PM
4Wheel's Avatar
4Wheel 4Wheel is offline
AF - Advisor
Re: Odd jerk when coming to a stop
Sounds like (a) bad control arm bushing(s).
Look very closely at the inner bushing shoulder where it protrudes out of the rubber it should be fairly symmetrical if the bushing is not hammered.
If there has been a chronic oil leak where oil has been in constant contact with any of the rubber in the bushings check those closely. I.e. power steering pump leaks will soften the rubber bushings on the passenger side.
Do you gat a lot of "rut steer" meaning does it wander and jump when crossing ruts in the pavement? Lose bushings can cause this.
Old 04-12-2006, 12:27 AM
no it steers fine. i think it is coming from the rear. i can sometimes feel it when the rearend goes over a speed bump. it feels like the rear end is shifting or something. i read something about dry splines? needs the to be greased up?
Old 04-13-2006, 08:56 PM
runner97 runner97 is offline
sounds like a similar problem I have with my 97 4Runner. Feels like someone is tapping your bumper right after you come to a stop. Feels like something in the transmission or drive train.
Old 04-14-2006, 12:13 AM
4Wheel's Avatar
AF - Advisor
What is your idle rpm with the transmission in neutral?
Old 04-14-2006, 08:52 PM
Brian R.'s Avatar
Brian R. Brian R. is offline
Resident Chemist
Send a message via Yahoo to Brian R.
Grease all the fittings on your propellor shafts, particularly the splines. I bet they are dry. Use moly grease.
Forum Guidelines:http://www.automotiveforums.com/vbulletin/guidelines.html
"What we've got here is a failure to communicate"
Old 04-17-2006, 10:54 AM
4Wheel's Avatar
AF - Advisor
Just an FYI to those getting thumped in the rear.
I was on a trip this weekend and thought I would test my original hypothesis.
I held the RPM at about 1800rpm and came to a stop and WHOA! The whole truck lerched and then settled what seemed like "back" I could replicate this every time with the "idle" set too high.
It is a side affect of the transmission shifting down under "acceleration" not a normal scenario.
Check your idle when in park or neutral just after you experience this "phenomenon".
Set it to your engines specifications (~800rpm).
Hope this helps.
Old 10-17-2011, 11:24 PM
LanPhantom LanPhantom is offline
Send a message via AIM to LanPhantom
I had that problem on my 99 4Runner 4x4 and lived with it for about 3 years. Finally I dropped 30.00 on a small grease gun and pumped some into the rear drive shaft yoke. You'll know what it is when you look back there. It comes off of the differential and connects to the drive shaft. You'll see a clean rubbed area where these two pieces slide back and forth. This is what they are designed to do. However, when they get dry of grease, they klunk when coming to a stop then releasing the brake.
Grease it up good and it'll either go away completely or quiet down.
Old 10-18-2011, 09:00 AM
Brian R.'s Avatar
Resident Chemist
See post #6
Old 10-18-2011, 07:23 PM
CMauro_75 CMauro_75 is offline
Yeah things can start to jerk, pop and creak when they start drying out and sticking.
