Go Back   Automotive Forums Car Chat > Honda > Civic | CRX > '96-'00 Civic
Old 04-11-2006, 05:14 PM
iCivic iCivic is offline
97 civic black smoke?
someone told me the black smoke comin outta the muffler is cuz of too much gas getting through? is that true, if so, what can i do?
ppl have given me some ideas, but alot and i don't want to do it all if i can hit it on the dot with the 1st try ya know, ppl mentioned timing could be off, ppl mentioned plugs, ppl mentioned a couple other things i forgot..
someone help lol
Old 04-12-2006, 03:44 PM
bluevp00's Avatar
bluevp00 bluevp00 is offline
Re: 97 civic black smoke?
I'd start by checking the small things first - replace your air filter, and your spark plugs. A bottle of fuel system cleaner wouldn't hurt either. Black smoke means the engine is running rich (fuel:air ratio has too much fuel - or too little air).
Old 04-13-2006, 05:41 PM
myjeepsux420 myjeepsux420 is offline
Send a message via MSN to myjeepsux420
O2 sensor?
1995 Jeep Wrangler
3 1/2" lift 33x12.50 tires
4.5L stroked I-6
Bored throttle body & Cold Air Intake
Jet Chip Stage 2
Jet Thermostat
Colorado Off Road Rig!!!
Old 04-13-2006, 05:55 PM
Originally Posted by myjeepsux420
O2 sensor?
that hard and/or expensive to replace?
Old 04-13-2006, 06:09 PM
O2 sensor?
Old 04-13-2006, 11:15 PM
bluevp00's Avatar
Hard - not at all, the O2 sensor simply bolts on, just like a spark plug.
Expensive - well, they run about $70-80 apeice, and you usually have to replace both of them at the same time.
Old 04-14-2006, 03:34 PM
that somethin im gonna need to go to the dealership for or any auto place?
Old 04-14-2006, 07:38 PM
CRXperiment's Avatar
CRXperiment CRXperiment is offline
replace it yourself. Buy one from an auto place.. like autozone, and make sure you rent out the o2 sensor ratchet adaptor too. This is an easy job, you can do it yourself. As for the lower o2 sensor, well are you comfortable with cralling under your car?
1989 Civic STD - sold
1991 CRX Si - current
Free Service Manuals: http://hondatech.info/
Old 04-15-2006, 11:14 PM
the upper one is hella easy to see, i checked it out, how would i know which is bad or if either is bad? any way to tell...
and yea i don't mind gettin under my car, just gotta find it along the exhaust pipe...
i'll go to autozone tomorrow and see what they charge for them and then rent the tool, probably do the upper one 1st being as it looks incredibly easy to do..
Old 04-16-2006, 02:10 PM
Dont worry about the rental tool. Autozone makes you put like a 15 dollar deposit down on it but if you bring it back theyll give you back your money. O2 sensors shouldnt be that expensive...good luck.
Old 04-16-2006, 07:27 PM
thanks for the help, i'll be gettin on it, was busy today but hopefully tomorrow it'll get done
