Go Back   Automotive Forums Car Chat > Dodge > Neon | Plymouth Neon
Old 04-11-2006, 04:27 PM
SRT-Wannabe SRT-Wannabe is offline
Strange Problem
I have 2000 dodge neon es Sohc 2.0L motor. Today I had driven it a good 30 minutes to an hour, and it's a atx. I sometimes like to manual shift it, only for higher rpm and torque purposes. This problem has been going on for about 2-3 weeks. The temp gauge goes up to about half and a little over half, warms up a little too quick as for my opinion. Thermostat is new and I have a 98 coolant fan motor since my other one has died. The coolant in there is fine, and I have a full resovoir. But here's the situation, when I put it in park, the engine starts to rev by itself, and it watch the rpm gauge closely. I watch it to below 1,000, which is strange cuz when I start it cold and in P the rpm stays at 1k. The highest I've seen the rpms go up to is 3,000. Could anyone tell me what the hell is wrong with my car, it's really depressing seeing my car in this state when I have such big plans and high hopes for it. plz?
Old 04-11-2006, 07:39 PM
Re: Strange Problem
can anyone help me out or what?
Old 04-12-2006, 07:09 AM
Re: Strange Problem
you know what forget it, since I'm forced to do this myself. Fuck it, doesn't matter, I thought I'd get some help with a problem that's driving me competely insane, no problem. THANKS FOR NOTHING EVERYONE!!!
Old 04-12-2006, 07:33 AM
das2123 das2123 is offline
Tuning Neons since '97
Send a message via AIM to das2123 Send a message via Yahoo to das2123
Re: Strange Problem
Chill out man, maybe people don't know what advice to offer. You're not gonna get help from most people acting like an ass.
Anyway, Coolant Temperature Sensor could be the cause of your temp gauge reading. Throttle Position Sensor could be the cause for the idle surges or it may be time to change your spark plugs. I would suggest not manually shifting an ATX, it's bad for the tranny.
Old 04-12-2006, 11:27 AM
Re: Strange Problem
I'm sorry dude, it was just an infuriating problem, but thx for your help.
Old 04-12-2006, 11:49 AM
neon_rt's Avatar
neon_rt neon_rt is offline
Re: Strange Problem
If you are going to manually shift your transmission, put a shift kit into it.
If you do very much inappropriate manual shifting the trans will wear out, the shift kit will prevent this and you can do all the manual shifting you want.
I've manually shifted all of my auto cars without any problem, but they need the shift kit to reliably do so. Most shift kits have a setting of mild, mid,race. I made the mistake of setting up one of mine for race and regretted it (chirped tire every time it shifted). I usually stick to mild, if you have NOS or Turbo, I would use Mid.
Old 04-12-2006, 12:17 PM
Re: Strange Problem
Hey thx for the advice dude, I had no idea. I have a question, I want to buy Bosch +4 platinum spark plugs for my neon, are those the best plugs to use? What do you suggest?
Old 04-12-2006, 01:50 PM
Re: Strange Problem
NOOOOOO!!!!!! Stock Champions are fine and cheap. Platinums do not work well with the neons wasted spark system. NGK's also work well, but NO PLATINUM PLUGS!
Old 04-12-2006, 02:21 PM
Re: Strange Problem
ah I see. You saved me from screwing up my car. there's something i noticed about my front passenger wheel. when the mechanic was driving my car to the other side of the shop, while making a left turn i heard my wheel grinding against the bumper, could there be a suspension problem with my front tires?
Old 04-13-2006, 08:00 AM
Re: Strange Problem
The wheel was running against the bumper? Are they stock tires and rims?
Old 04-13-2006, 10:26 AM
Re: Strange Problem
nope. I have 15' konig rims with 15' 195/60 radial gt-a tires.
Old 04-13-2006, 10:04 PM
Re: Strange Problem
^^^I was thinking maybe your wheel/tire setup was too big, hence the rubbing. That doesn't look like the problem though. Could be suspension parts wearing down, maybe springs and/or struts.
Old 04-13-2006, 10:32 PM
Re: Strange Problem
the rear struts are going bad, if not bad already, could that be the problem? or are the fronts starting to join the party with the rears? oh yea, i forgot to ask, but where is the throttle position sensor located?
Old 04-14-2006, 10:53 PM
Re: Strange Problem
On the throttle body.
Old 04-15-2006, 07:37 PM
Re: Strange Problem
kewl man, thx
