Go Back   Automotive Forums Car Chat > Jeep > Wrangler
Old 04-11-2006, 02:01 PM
jeepndanes jeepndanes is offline
Oil Leak Normal?
Well, another problem with my Jeep.
I have a 2003 Wrangler Sport. Oil is leaking from between the engine and transmission. I took it to the dealership this morning. Guess what they told me... it is NORMAL! WHAT?! I have so had it with Jeep service. That can't possible be true.
Has anyone else received this type of service? I live in central VA (Richmond). ANyone out there know of a respectable Jeep service department?
Old 04-11-2006, 03:01 PM
wilwith1l's Avatar
wilwith1l wilwith1l is offline
Re: Oil Leak Normal?
Thats funny. That sounds like a lot of mechanics I know. He could be sayin "It ain't worth worryin about."
Old 04-11-2006, 09:30 PM
wilson05's Avatar
wilson05 wilson05 is offline
Send a message via ICQ to wilson05
man to be honest i have a 95 yj and its leaked ever since i got it and its never caused problems and yes i'm sure its probably from the same place that its comin out cause its dripping onto my skid plate and then down from there... but its probably not worth worrying about just mabye once a week check our oil.... even though you'd probably be fine i'd just like i said keep check and make sure ya know.... better safe than sorry
Old 04-11-2006, 11:41 PM
o|||||||o o|||||||o is offline
Send a message via AIM to o|||||||o
If it is still under warranty make them fix it... There is nothing in the owner's manual about routine oil leaks. I am sure that they are not going to tell you that is supposed to leak. If it isn't under warranty then do the check the oil thing periodically and live with it.
2004 Jeep Wrangler Rubicon (Modified a lil' bit)
2003 Honda VFR 800 (All stock w/ABS, just like Honda built it)
2001 Ford Crown Victoria Police Interceptor (It looks like a cop car because it is one)
Old 04-12-2006, 06:14 AM
Ray H Ray H is offline
Leaky rear main seals and leaky valve covers may be "common" but I would never consider an oil leak "normal". It can also be difficult to tell the two apart without looking hard. Obviously the valve cover is much easier and less expensive to fix than the rear main. If you feel you need to get the leak fixed, make sure of what is leaking before plopping money down for labor. If its under warranty, have them fix it because, while it may be common, its not supposed to leak.
The rear of the 4.0 in my XJ is always wet but doesnt leak enough to effect the oil level or even drip. Its done it for a few years and Ive never bothered to fix it and probably wont as long as it doesnt get worse.
Old 04-12-2006, 06:52 AM
Thanks all for the kind words. The Jeep is still under warranty. So, after much deabte over the leak, they have opted to fix it. Of course, they didn't even order the part yet... and they still calimed they couldn't hear the loud clunk in the engine. As a matter of fact, they were more worried aboiut my rear diff fluid being changed than anything else. I told them I'd do it before my seal change appointment and let them know if it solved the clunk (not likely). Well, I changed the fluid last night and the clunk is still there. To add a little salt in my wounds, the fluid was pristine... (I am a vigorous maintainer of my vehicles).
Oh well, I hope they at least do the job right when they do finally get to it. The thing to remember is that while something might be "normal" it isn't necessarily correct. (someone else previously stated here, and my argument to them yesterday). My leaky seal had been a problem since early on, and they blamed it on everything else. With oil dripping out, there was no way they could deny it this visit.
Old 04-12-2006, 12:33 PM
fredjacksonsan's Avatar
fredjacksonsan fredjacksonsan is offline
Caution: Monkeys bite!
Send a message via AIM to fredjacksonsan
Leak + Warranty in effect = dealer, suck it up!
On an older vehicle, you might try this stuff: www.auto-rx.com. I've used it, and it work as advertised, though I can't vouch for the claims it will stop leaks, I switched a 90K 4.0L from regular to synthetic oil, without leaks.
Ours: 2020 Jeep Wrangler 2.0, 53k
2013 Toyota FJ Cruiser, 84k
Kids: 2005 Honda CRV, 228k
