Go Back   Automotive Forums Car Chat > Geo > Tracker
Old 04-11-2006, 11:03 AM
DOCTORBILL's Avatar
DOCTORBILL DOCTORBILL is offline
Geo Metro Lover
How do you free up a Tracker 4WD hub..?
I have a '93 Tracker 1.6 L 4WD.
The right side hub will not turn from free to lock by hand - it is stuck.
How can I free it up?
I don't want to try to force it with pliers.... might break it!
Would spraying it with WD-40 get it loose or screw something up?
DoctorBill
Old 04-11-2006, 03:49 PM
viperh viperh is offline
Send a message via AIM to viperh Send a message via Yahoo to viperh
Re: How do you free up a Tracker 4WD hub..?
DoctorBill
I would spray it with liquid wrech (its like wd40 on crack) Or PB Blaster.
choice is up to you.
Old 04-11-2006, 09:27 PM
gumby_ct gumby_ct is offline
Doc,
Sounds to me like grease is in order.
1998 Chevy Tracker 4dr, 4wd, auto,
1996 2dr Metro LSi, 3Cyl. 5spd, 107k mi.
My other car...in need of repair it won't start any longer
1995 2dr Tracker Conv. 4wd, 5spd, A/C 170k mi. (My Fav)
Old 04-12-2006, 09:42 AM
DOCTORBILL's Avatar
Geo Metro Lover
Got it loose finally with penetrating oil and some pliers.
Be nice to have some heavy plastic or wood tool to give one more leverage.....
DoctorBill
Old 05-08-2006, 09:29 AM
Veezer93 Veezer93 is offline
The Good Dr,.
I have seen WARN hub tools at www.4wd.com. It's like a big socket that is notched for the thumb/turn bar
Old 05-12-2006, 10:42 AM
Mad_Squirrell Mad_Squirrell is offline
i just went through this a few weeks ago you need to remove the hub and dissasemble it to clean it up its probobly rusted . i got mine to break free too but the hub was not locking in even after it turned.
take the whole hub off the axel first then remove the allen bolts on the work bench then tap the locking gear out of the hub (the reason i say to do it this way is that the spring and keeper are a pain in the butt to re-assemble) then clean up the gears with a good cleaner for removing rust like aerocroil, lube it and reassemble .................good as new
