Go Back   Automotive Forums Car Chat > Dodge > Dakota
Old 04-11-2006, 10:33 AM
microvault microvault is offline
Send a message via AIM to microvault Send a message via MSN to microvault
Speed Sensor
does anyone know where the speed sensor is located on a 93 dak with a 3.9l auto is located. i dont think that it is working properly cause it is not shifting properly down or up, seems to shift up soon and shift down late. Or if anyone else knows what could be wrong???
Old 04-11-2006, 09:26 PM
troy1 troy1 is offline
AF -Advisor
Re: Speed Sensor
On a 93 the only thing that is controlled by the speed sensors and various other sensor is torque converter lockup and 4th. Every thing else is hydraulically control by the transmission. You might want to have the kick down cable checked and adjusted as needed this can cause late/early down/up shifts it can also burn up all the clutches if adjusted improperly do to low line pressure.
