Old 04-11-2006, 01:27 AM
AFI 05 AFI 05 is offline
Send a message via AIM to AFI 05
look'n for a driveshaft
okay, i now have some cash to spend... i want an aluminum driveshaft .. I think I remember somebody on here who was selling them. I'm pretty sure an LS1 driveshaft will bolt up like this
one... RIGHT? correct me if im wrong please.
1990 IROC-Z 5.7 TPI (1 out of 4,213 IROC's made in 1990) Only mod is magnaflow 3" cat back and K&N filters... im broke.
Old 04-11-2006, 02:35 AM
blindeyed's Avatar
blindeyed blindeyed is offline
eBay aDdict™
Send a message via AIM to blindeyed
Re: look'n for a driveshaft
yeah John (FormulaLT1) sells em at a pretty good price. You can PM him or just wait till he see's this thread.
- Jason
1995 Pontiac Firebird
User Guidelines | VB Codes Explained | AF Merchandise
"Each of us, is in the scheme of things, insignificant.
But millions of insignificant people, doing a tiny bit,
can add up to be a very significant force."
Old 04-11-2006, 05:12 AM
drvngstorm05's Avatar
drvngstorm05 drvngstorm05 is offline
ya get john's shaft, i have one, john whores them out, his shaft goes everwhere lol
'92 RS lt1/t56, lt4 hot cam, 30lb injectors, 54mm throttle body, full exhaust, 4.11 posi, 4 coil ignition, alluminum driveshaft, adj rear suspension, low. springs, electric water pump, custom tune.
Old 04-11-2006, 10:59 AM
92zcamaroperson's Avatar
92zcamaroperson 92zcamaroperson is offline
Youll also recieve a completmentary piece of artwork that john refers to as a box. lol jk john
92 z28 camaro 5.7 TPI
current - slp intake runners and base-BBK 52mm throttle body-MSD 8.5mm wires, blaster coil, and 6AL Box-edelbrock headers-160 degree stat.-hotchkis strut tower brace
waiting in the garage - LQ4, milled heads 317 casting (10.5 to 1), hardened pushrods, ported LS6 oil pump, manley dual spings with titanium retainers, MTI X1 cam, hawks longtube headers
Old 04-11-2006, 11:16 AM
wrightz28's Avatar
wrightz28 wrightz28 is offline
is bring'n sexy back
I heard he packs 'em with jello from his jacuzzi too
in all seriousness, they're aluminum LT1 shafts right? what about balancing?
Old 04-11-2006, 11:49 AM
lmao.. ill see what kind of shaft john can give me hahaha. then ill stroke it so its nice and shiny
Old 04-11-2006, 11:53 AM
oh yeah and for those of you who have gone with an aluminum, is it tough to install? im on spring break so i have some time on my hands in the mornings aside from work. Im also getting my wheels re-finished.. ill post pics when those are done.. probably by friday.
Old 04-11-2006, 11:54 AM
1986Z28's Avatar
1986Z28 1986Z28 is offline
Has a Camaro
Send a message via MSN to 1986Z28
formulalt1 can get you one, 165 i think i said with heavy duty u joints send him a pm
Formerly Blownalcoholboy
1986 Z28, 400ci SBC, Twin borg warner billet S467 turbos, Reid case powerglide, Moser 9". Holley EFI, Boost Leash. 950RWHP on pump gas, 1200rwhp on race gas (22 psi)
Best ET 1/4: 8.35 @ 170mph (275 drag radial)
Best ET 1/8: 5.44 @ 132mph (275 drag radial)
Best 60': 1.31 on the back tires (275 drag radial)
AF User Rules/Guidelines
http://www.automotiveforums.com/vbul...uidelines.html
Old 04-11-2006, 12:05 PM
tcfco2005 tcfco2005 is offline
no there easy as hell to install...just jack up the front...get under there remove the four bolts from the rear end yolk or whatever its called and then it slided of the tranny and just reverse to put it back in...you might have to take it out and rotate it so it is balanced on there
1991 RS
305 T.B.I.
700-R4
Old 04-11-2006, 12:14 PM
how do I balance it? rotating it and what am I looking for..
Old 04-11-2006, 12:17 PM
Jcrane88 Jcrane88 is offline
Send a message via AIM to Jcrane88
1984 Camaro 5.7L 350
700R4
Holley 650 Cfm
Edelbrock Performer Intake-Manifold
Crane Cams Duration @ .050": 204/214 Lift:420/442
Summit HEI Distributor
Hedman Shorty Headers
Hedman Y-pipe
Dynomax Turbo cat-back
NOS Decal
VTEC Decal
Old 04-11-2006, 12:46 PM
well after you put the aluminum driveshaft on you might or might not get vibrations...if you do thats when you take it off and rotate it and just keep doing that till the vibrations are gone...
1991 RS
305 T.B.I.
700-R4
Old 04-11-2006, 12:52 PM
1986Z28's Avatar
Has a Camaro
what kind of person would want to get the shaft from john anyway
Old 04-11-2006, 01:00 PM
lol apparently, johns shaft is appealing to some people here. a few of them have gotten his shaft and seem satisfied.
Old 04-11-2006, 01:03 PM
ahh gotcha.. i guess ill HAVE to go 120+ to find out.
