Old 04-11-2006, 01:41 AM
blackjay8o blackjay8o is offline
97 cav probs Please Help
This might be 2 seperate problems, but i think they might be related.
First, when i go over 45mph, it makes a loud humming sound, almost like i have a flat tire, but without the thumping. Tires are not to old. Friend said maybe wheel bearings.
Second, when i am hitting my brakes, about every other time it makes a rattling sound. it stops okay, but i don't know what it is.
Any help is appreciated, thanks!
Old 04-11-2006, 04:16 AM
muff34 muff34 is offline
Re: 97 cav probs Please Help
1 could be the bearings, if you wiggle the wheel ABIT does it disappear for a second or so? yes - bad bearing 2 loose pads ,maybe there coming apart
Life Is A Highway ,Enjoy The Ride
Old 04-11-2006, 01:14 PM
I think it is the bearings. Is that expensive get fixed?
Old 04-16-2006, 06:17 AM
Doc Blazer Doc Blazer is offline
Its the bearings. I just changed both front bearings on a 97, they are 65 dollars appiece at auto zone . Easy job to do although you need a big socket for the half shaft (axle) nut. 1and 1/8 I think also a torque wrench that nutgets torqued to 180 ft lbs. You also need a set of allen wrenches to remove the brake calipers and a star bit to remove the bearing hubs. Takes about 30 minutes per side.
