Old 04-11-2006, 12:27 AM
blackjay8o blackjay8o is offline
97 Cav Probs, Please Help
This might be 2 seperate problems, but i think they are related.
First, when I go over 45 mph, it makes a loud humming noise, sounds like it is coming from my tires. Friend said maybe wheel bearing. Tires are not to old and not low.
Second, when I hit my brakes, about every other time it will make a rattling sound.
Any help is useful, thanks.
Old 04-11-2006, 11:56 AM
Cold_Silence's Avatar
Cold_Silence Cold_Silence is offline
Send a message via AIM to Cold_Silence Send a message via MSN to Cold_Silence
Re: 97 Cav Probs, Please Help
The rumbling at a high speed is one of a few things, something in your rims ex: snow, mud, etc. Or, it could be your wheel alignment which I just had done and it fixed it right up, OR it could be your wheel bearing(s). Is is coming from a specific side or just from the front from what you can hear?
The New Ride!! 2002 Cavalier Coupe..
Originally Posted by noshun
It's a lovely 2200, but got about as much poke as my grandma with no fingers.
www.cleanstartsolutions.com
Old 04-11-2006, 12:11 PM
Yes, it just comes from the front from what I can hear
Old 04-11-2006, 12:14 PM
Check if your allignment is off, find a flat straight road and preferably a non-windy day, and straighten the wheel and let go. If it veers off to any side then the alignment is off and that could be it. I still have a good feeling its one of your wheel bearings or both. Get them checked/replaced and see if that helps. Do you have mags or just steelies for rims? Make sure they're not bent.
Old 04-11-2006, 12:21 PM
BlasZ24 BlasZ24 is offline
Sounds like it is most likely a wheel bearing. to check your bearings jack the car up and grab the wheel on both sides and try moving it(dont be too gentle), if you feel it move around then you need to replace the bearing.
Old 04-11-2006, 12:41 PM
thanks, is that expensive to go get fixed?
Old 04-11-2006, 12:52 PM
If you know how to do it yourself its very cheap, but for some reason its pricey to get done. I got quoted like 180 canadian. so around 140-150 us?
Old 04-11-2006, 06:22 PM
I recently had 2 wheel bearings replaced, one at the shop for about $350 can parts and labour and another I did myself ~$100 can.
