Old 04-10-2006, 11:43 PM
Eclipse4ever's Avatar
Eclipse4ever Eclipse4ever is offline
The GSX is apart, need some help.
Well I drained all the oils and stuff out of the car and I took out the exhaust manifold, the turbo is off, and the intercooler plus the piping and the intake system. I will be putting some Mobil 5w30 Mobil 1 full synthetic oil in the engine, some tranny oil like crynchymilk55 suggested but what do I use for the rear deferencial ? Also I just bought a Ebay intake plus NGK wires and Iridium spark plugs BUT I forgot in which order the spark wires go !!!
I ordered some FMIC off ebay that was 28x12x3 and a manifold that looked alrite with lifetime warranty ( Not SSautochrome even though I find nothing bad about them ). I was going for a downpipe but it turns out that the Apexi exhaust came with a 3" downpeipe so I am glad its 1 thing I dont have to buy.
Also, I am getting the car tuned next week and I hope that I have some time slips for you guys because I will be running it right after I get it tuned.
By the way, is it better to have 2.5" or 3" intercooler piping all around or ?
Thanks
1997 Eclipse GSX
Old 04-11-2006, 09:49 AM
defiancy's Avatar
defiancy defiancy is offline
Stay classy San Diego
Re: The GSX is apart, need some help.
Thanks
The differential uses the same fluid as the tranny.
3'' intercooler piping will move more air. If there is a 3' outlet on the intercooler go with that, if it's a 2.5 outlet on the intercooler go with the 2.5
1991 GSX 2.3 Stroker
Old 04-11-2006, 01:49 PM
ez1286's Avatar
ez1286 ez1286 is offline
Send a message via AIM to ez1286
Don not use iridium plugs in a turbo car. They are shit, you should be replacing your plugs every oil change anyhow and i doubt you want to spend that much every time. My brother had ngk iridiums in and his car stumbled wierd, someone suggested plugs so he got a new set (this was over a years ago and it was $60+ per set) still happened so he replaced the coil. Ended up that $5 worht of genuine ngk bpr7es's did the job.
95 GSX:FMIC, 6-bolt, evo 3 16g, 2600 act clutch, 1g bov (crushed), and a 3" turbo back exhaust, dsmlink, dks 272 cams, wideband 02, Coming soon 2.3L Stroker, 1mm oversized valves, crower sprigs. 91 TSI AWD auto, gm 3.5 maf, maft, fmic, emanage, profec e-01, 3" turbo bk exhaust +more little stuff.
http://www.ratemydsm.com/member/ez1286/?member=ez1286
Old 04-11-2006, 01:56 PM
defiancy's Avatar
I would hardly call some Denso's shit plugs.
Old 04-11-2006, 03:19 PM
blk_srt's Avatar
blk_srt blk_srt is offline
Send a message via AIM to blk_srt Send a message via MSN to blk_srt
the order from the coil is 4123 and the engine left(drivers side) to right(passengers side) is 1234
2004 Flame Red SRT-4
|Audiobahn 1200Q|Rockford 602s|Jensen flip out dvd|
Mods:
Old 04-11-2006, 03:43 PM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
If you haven't been running synthetic before, I wouldn't suggest swapping over. Just keep running what you have been running and you shouldn't have any problems. I've had problems with two motors after switching from regular to synthetic.
95 Talon TSI AWD
97 Eclipse GST
Old 04-11-2006, 03:57 PM
blk_srt's Avatar
switching from conventional to syntethic doesnt do anything to your motor. People assoiate synethic oils to causing leaks, well they dont, what the do is clean the motor better exposing spots that would have leaked but were covered by gunk. I've done countless hours of research on this subject and I also had to take a class on oil for my ase certification
Mods:
Old 04-11-2006, 04:15 PM
crunchymilk55's Avatar
crunchymilk55 crunchymilk55 is offline
Send a message via AIM to crunchymilk55
Do not use 3" intercooler piping, that's too much volume to us. 2.5" is plenty
I recommend synthetic oil and fix any leaks that arise from the switch.
now - 2000 civic
soon - 2002 is300
Old 04-11-2006, 04:50 PM
OK i just got some chrome 2.5 pipes from my friend's dad store. I'll use one of those bending machine they sell at Home Depot or something. The intercooler is on the way. The turbo however was oily, the car has been running synthetic for 5 years, but I did not notice to burn any oil.
I guess my question is this. I got the pipes. What shape am I suppost to bend em ? I mean I searched around here and there, and I found that there are long or short intercooler kits but since I would like to do one myself I just didnt know how to set it up.
I looked at people's intercooler kits and its like 4 peipes but can you guys give me a website or directions to how many pipes I need and which way would it need to be bended.
1997 Eclipse GSX
Old 04-11-2006, 05:06 PM
95_GSX's Avatar
95_GSX 95_GSX is offline
Send a message via Yahoo to 95_GSX
Get a tape measure and try to create the shortest pipe routing possible.
You know that chrome is going to blue when you weld the BOV flange on right.
Got AWD?
Some people buy super cars, other build them
----Click It, For Mods and Pics----
'95 Mitsubishi Eclipse GSX - For Sale
'05 Volkwagen Golf GLS TDI - My daily driver
'03 Ford Excursion 6.0L PSD 4x4
'13 Ford F150 FX4 SCREW 4x4 3.5L EcoBoost
'08 Buell 1125R
'83 GMC Sierra Classic K2500 4x4 - Future Cummins Swap
Old 04-11-2006, 07:34 PM
ez1286's Avatar
I don't know if those benders will work on 2.5" piping. Also they do not mandrel bend the tubes which i'm not sure how big of a difference it will make.
