Old 04-10-2006, 11:24 PM
leobags leobags is offline
leaking AEM fuel rail
i was wondering if anyone knows what to put on the threads to stop the leak from one of the top next to the fuel pressure regulator. it slowly seeps out gas thanks for ur help.
Old 04-11-2006, 12:24 AM
civic_boy91's Avatar
civic_boy91 civic_boy91 is offline
Send a message via AIM to civic_boy91 Send a message via Yahoo to civic_boy91
Re: leaking AEM fuel rail
get a copper washer o-ring thing... i had the same problem... i alos used silicone II (a bead around the bolt head).. it worked fine
_________________________________http://VelocityFactor.com________________________________
1990 si hatch
b20b si tranny
megan race header 2.5 custom exhaust
50 shot
integra da rear disk (w/ 4040 valve)
powerslot rotors and barded lines all around
1994 Dx hatch
stock
Old 04-11-2006, 07:44 AM
kris's Avatar
kris kris is offline
Off playing with fire.
I believe the top whole is a allen plug right? If it is, pick up some yellow teflon tape, pull the plug out, wrap it up, and thread it back in.
Old 04-11-2006, 11:10 AM
bambam89lx's Avatar
bambam89lx bambam89lx is offline
AF - Advisor
Send a message via AIM to bambam89lx
it should stop leaking if you just tighten the bolt down tighter. You have to remember, your fuel system is under alot of pressure, so that bolt has to be VERY tight. Also, make sure you're not missing any of the associated washers.
Jumper harnesses, mpfi conversions, engine harness conversions, vtec subharnesses, etc.
The absolute lowest prices at the absolute highest quality. Trusted. Guaranteed.
Click the image above to visit our online store!
Hastings Bseries and Dseries piston ring kits (inc. ZC) - $49 shipped
Old 04-12-2006, 10:10 PM
I tightened the bolt to the max and it still seeps out, so this silicone II where do i get that and for the yellow teflon is not like the white, right! it can with hold the gas. thanks everyone for ur input.
Old 04-13-2006, 08:04 AM
bambam89lx's Avatar
AF - Advisor
you are SURE the washers are installed and installed in the right direction right?
Old 04-13-2006, 01:36 PM
FrodoGT's Avatar
FrodoGT FrodoGT is offline
Just to let you know, teflon tape does not seal the threads...it simply lubricates them allowing the bolt to get a little tighter..the tape doesnt help sealing at all, that's 15 years of my dad, a master plumber, rambling on all day!
Cheap, Fast, Reliable..Pick two
Current project:
Rio Red 91 hatch.
A6/Z6 build, Hondata S300, Tokico illumina/Ground Control.
"I'd rather run 12's on steelies than 15's on rotas."
Old 04-13-2006, 07:27 PM
kris's Avatar
Interesting. I guess all my fittings are pouring out fuel right now...
Anyways, yes, yellow teflon is fine for fuel lines. Stay away from the white though.
