Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 04-10-2006, 10:22 PM
wanaplay134 wanaplay134 is offline
Send a message via AIM to wanaplay134
runing rich for some reason
i was being followed by my buddy and he said i was blowing black smoke and it smelled like gas. which i figure is a sign of runing rich does anyone know what i should check to fix it.
i have brand new plugs and wires that are gaped correctly and have like 50 miles on them. and everything i can find seems to be hooked up right.
1992 eagle talon tsi awd
xtd stage 3 six puck/apexi 3' downpipe and exhaust/ngk plugs/taylor thunderbolt wires/manual boost controller set at 20psi/walbro 255 with rewire/autometer boost gauge/turbo xs rfl blow off valve/arp headstuds/ to4b vtrim turbo/dnp tubular manifold with o2 housing and tial 38mm wastegate/eagle rods/ross pistons/acl bearings/arp rod bolts/arp main studs/aeromotive fuel pressure regulator and all stainless lines/aem fuel rail/slowboy street front mount kit
Old 04-10-2006, 10:26 PM
blk_srt's Avatar
blk_srt blk_srt is offline
Send a message via AIM to blk_srt Send a message via MSN to blk_srt
Re: runing rich for some reason
do a boost leak test
2004 Flame Red SRT-4
|Audiobahn 1200Q|Rockford 602s|Jensen flip out dvd|
Mods:
Old 04-10-2006, 10:46 PM
alright ill do that as soon as i wake up in the morning im pretty sure my turbo is leaking boost at my o2 housing it doesnt pull right and makes a whistling noise.
Old 04-10-2006, 10:54 PM
blk_srt's Avatar
if it was at your o2 housing it would be leaking exhaust. You were probably thinking your j pipe. Thats a common spot
Mods:
Old 04-11-2006, 07:37 PM
alright so i did a leak test and all that my one lower intercooler pipe was leaking so i fixed that and redid the test and found nothing at all. but that wasnt the problem at all. now my car runs like shit and stumbles under acceleration, and makes wierd poping noises when i press the gas.
Old 04-11-2006, 07:39 PM
crunchymilk55's Avatar
crunchymilk55 crunchymilk55 is offline
Send a message via AIM to crunchymilk55
sounds like a spark issue, check deeper into the system
now - 2000 civic
soon - 2002 is300
Old 04-11-2006, 07:56 PM
blk_srt's Avatar
sounds like the same thing that my car is doing. That being the igntiion timing is retarding. I think my problem is caused by the knock sensor.
Mods:
Old 04-11-2006, 11:00 PM
is there a way to check the knock sensor or should i jsut replace it cause i mean its a 92 and has been on there its whole life so its probally bad or going bad.
Old 04-11-2006, 11:43 PM
blk_srt's Avatar
I wouldnt randomly replace it, its a $40 part and a bitch to get to. If you can wait let me figure out the problem on my car(thursday, tomorrow is my day off) and I will let you know whats up. If not try doing some tests, since you have a 1g you can adjust your base timing with your cas so you could try that to
Mods:
Old 04-12-2006, 01:55 AM
alright well let me know. yea i could do that it is idling high also like at 1300 rpm instead of the 800 or whatever it should be at
