Go Back   Automotive Forums Car Chat > Pontiac > Bonneville
Old 04-10-2006, 10:05 PM
truc0011 truc0011 is offline
1994 Bonneville Cam Shaft position sensor
Can anyone give me some tips on replacing the Cam shaft position sensor? Where it is? And how to remove it?
Thanks!
Old 04-10-2006, 10:49 PM
hardparts hardparts is offline
Re: 1994 Bonneville Cam Shaft position sensor
The cam shaft sensor is located behind the water pump pulley. One bolt that holds it in place
http://www.hard-parts.org/forum
New automotive tech site.
Just opened, come join us.
Old 04-11-2006, 07:37 AM
sixsmiles sixsmiles is offline
It is on the front of the engine on the aluminum timing chain cover, jack up car remove RF wheel. You can find the cam position sensor on the Timing Chain Cover.
Old 04-11-2006, 07:52 AM
Thanks to both of you. I will give it a shot!
Old 04-11-2006, 12:30 PM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
If reference to the harmonic balancer, it is between 10 o'clock and 11 o'clock. There is a magnet in the cam gear that is what the cam sensor gets it's signal from which could be missing causing your Cam Sensor code. Be sure to roll the engine over by hand while the cam sensor is out and make sure the magnet is still in there. It is held in the gear by a small plastic cage that can fall apart from and cause it to go bye-bye.
Still waiting for the "good old days" I'll get to bore my future grandchildren with!
