Old 04-10-2006, 09:35 PM
pbrizzle86 pbrizzle86 is offline
Send a message via AIM to pbrizzle86
Brake problems
about a week ago my master cylander went out and took the booster with it replaced bolth and the front calipers and hoeses. i can drive the car fine for about 5 -10 min and then the front brakes stay stuck on and the pedal becomes rock hard i dont understand everything is new and works properly for a little while and then just stops. any help would be great.
Old 04-10-2006, 09:50 PM
FrodoGT's Avatar
FrodoGT FrodoGT is offline
Re: Brake problems
Well if you say they stay on..what makes them unstick?
Cheap, Fast, Reliable..Pick two
Current project:
Rio Red 91 hatch.
A6/Z6 build, Hondata S300, Tokico illumina/Ground Control.
"I'd rather run 12's on steelies than 15's on rotas."
Old 04-10-2006, 10:13 PM
Re: Brake problems
i dont know every time it has done this i have let it sit over nite and come back to it the next day and the brakes have relaeased
Old 04-10-2006, 10:32 PM
CRXperiment's Avatar
CRXperiment CRXperiment is offline
Re: Brake problems
Maybe you've got air in your system or a hole in one of your brake lines?
1989 Civic STD - sold
1991 CRX Si - current
Free Service Manuals: http://hondatech.info/
Old 04-10-2006, 10:56 PM
Re: Brake problems
i have looked over all the lines and hoses replaced the front hoses the rear was fine and bleed them over and over and over .they work perfect for a little while and then all of a sudden ill go to brake and the pedal is like a rock and the fronts are stuck on and wont release
Old 04-11-2006, 11:13 AM
bambam89lx's Avatar
bambam89lx bambam89lx is offline
AF - Advisor
Send a message via AIM to bambam89lx
Re: Brake problems
possibly your master cylinder is sticking. Did you bench bleed your MC?
Jumper harnesses, mpfi conversions, engine harness conversions, vtec subharnesses, etc.
The absolute lowest prices at the absolute highest quality. Trusted. Guaranteed.
Click the image above to visit our online store!
Hastings Bseries and Dseries piston ring kits (inc. ZC) - $49 shipped
Old 04-11-2006, 03:30 PM
Re: Brake problems
yes i bench bleed the mc there was no air in it when i installed it.i think i figured out the problem anybody know of an easy way to adjust the push rod that conects to the pedal
Old 04-11-2006, 05:42 PM
bambam89lx's Avatar
AF - Advisor
Re: Brake problems
yah, lay down in the driver's side footwell with a flashlight or drop light. I think it's either a 12 or 14mm...use a box wrench and tighten it.
Old 04-11-2006, 05:46 PM
FrodoGT's Avatar
Re: Brake problems
Haha! Ive spent more time in the footwell of my car than my feet have...But yeah, its right there, down..then up, way up!
Current project:
Rio Red 91 hatch.
Old 04-12-2006, 08:22 PM
Re: Brake problems
it seems like no matter where i position the clip for the pedal i get the same result its driving me nuts .the only way i can get the brakes to act normal and the brakes to realease is to losen the m-c from the booster enough to break the air seal and then the brakes work like the should.
Old 04-13-2006, 08:02 AM
bambam89lx's Avatar
AF - Advisor
Re: Brake problems
did you mess with the check valve on the booster (the white valve above the MC)?
Old 04-13-2006, 01:52 PM
Re: Brake problems
the check valve seemed fine there was plenty of vacum when i tested it
Old 04-14-2006, 11:28 AM
Smoghog Smoghog is offline
Re: Brake problems
I know this sounds stupid but did you put the check valve on in the wrong direction??? Look on it there should be a little arrow that points to the engine.
If that is not it you might have a kinked line somewhere??? Just guessing at this point...
SH
Old 04-14-2006, 12:02 PM
bambam89lx's Avatar
AF - Advisor
Re: Brake problems
yah, that's why i was asking, it only works in one direction. Also, make sure your booster is tightened down. You didn't need to replace the booster anyway, as it is only a vacuum chamber and has no moving parts. Make sure it is not leaking.
