Go Back   Automotive Forums Car Chat > Saturn > SC/SL/SW
Old 04-10-2006, 08:56 PM
5h0b4 5h0b4 is offline
Tranny Or Fuel?!?!?!?
My 1996 SL2 is crazy. I just had the water pump replaced after i got STUCK in chattanooga Tenn. Well, When I am going up a hill, the car will shudder between 1000 and 2000 rpms. It also does this if I try to take off really fast. I thought it was the Transmission and I changed the fluids but it is still the same thing. I haven't done any work to the fuel system other than the usual fuel filter replacement. So what could it be.
Old 04-12-2006, 12:01 AM
sierrap615 sierrap615 is offline
Master Tech Wanna-be
Re: Tranny Or Fuel?!?!?!?
what transmission? auto or manual
Daily driver: 1995 Buick Regal Custom 3.8L 4T60-E 150K miles
Gone: 1994 Saturn SL2 1.9L MP3 168,666 miles
EPA 608 Universal Certification
EPA 609 Certification
Old 04-12-2006, 08:08 AM
Cat Fuzz Cat Fuzz is offline
Just because you changed the trans fluid it doesn't eliminate the trans as the problem. Weak fluid pressure caused by a worn pump can allow the clutch packs to slip.
Old 04-13-2006, 11:20 AM
saturnspeed_12's Avatar
saturnspeed_12 saturnspeed_12 is offline
im going to say its not a fuel issue. its either something up with the trans, possible valve body issue which is a common issue on the autos, or your engine mount is bad.
strange to think it could be just an engine mount, but at the rpms you specified you could be making it under a big load and the engine is just jumping around and due to a bad mount can cause some nasty shuddering. the mount thats almost always the problem is the top mount on the passenger side.
Ian
Saturn Tuners Club-OH Chapter President
1993 Saturn SC2 rebuild project for dad
1995 Saturn SL2 current daily driver /w a lot of work
2007 Chevy Cobalt injen cai, full lsj exhaust, dc sports fsb, progress springs and rear sway bar, enkei wheels/hankook rubber --*boost in progress
