Old 04-10-2006, 09:08 PM
masterjess masterjess is offline
How do you fix rough idle on '92 S10?
my 1992 chevy S10 4.3L is a bit rough on idle. Yesterday I changed all sparkplugs and the cables but still a bit rough. Is there other way to fix this?
Old 04-10-2006, 10:22 PM
jackass#1's Avatar
jackass#1 jackass#1 is offline
Send a message via Yahoo to jackass#1
Re: How do you fix rough idle on '92 S10?
cap and rotor. fuel filter.
Old 04-11-2006, 09:25 PM
cool... I will try to replace the rotor, dis. cap and fuel filter. I will let you know if its fix the problem. thanx a lot.
Old 04-12-2006, 12:33 AM
dmbrisket 51's Avatar
dmbrisket 51 dmbrisket 51 is offline
Send a message via AIM to dmbrisket 51
if it is running fine, check the balencer for play, and check the rubber moter mounts, to see if they are in tact, easyer said then done, but both will cause a rough idel but run fine
Old 04-12-2006, 04:57 PM
yes, the truck runs great its just have just lil rough idle. By the way, what is balencer and rubber motor mount? where exactly i can locate it?
Old 04-12-2006, 06:25 PM
jackass#1's Avatar
the balancer is the biggest and the bottom pulley on the engine. the motor mounts are just that. one on each side of motor where the motor mounts to the frame. its a metal bracket with rubber cushions.
Old 04-13-2006, 11:47 PM
I just replaced the distributor cap and the rotor about couple hours ago. The cap and rotor were look really bad and old, but, now it runs much better and roughness is gone. I might need to replace the fuel filter too. Do I need to put fuel treatment? if so, what do you suggest for this old truck? At the shop they want to charge me $65 to mix a bottle of fuel treatment. I think its too much for just that. Also, some people told me that it might mess up the fuel injector so, I'm not sure if I want to put fuel treatment. btw thanks for your help, you did well.
