Old 04-10-2006, 06:57 PM
jamc204 jamc204 is offline
Fuel filter change
How often do you guys recommend changing the fuel filter? I have 2002 GP SE w/ the 3.1 engine.
Thanks,
Joe
Old 04-10-2006, 07:58 PM
BNaylor's Avatar
BNaylor BNaylor is offline
Re: Fuel filter change
You may have noticed GM doesn't specify an interval for the fuel filter, however, filter companies recommend every 25,000 miles. I do mine annually.
Timeslip 08/12/06
AF Community Guidelines
Old 04-13-2006, 01:36 PM
wlkjr's Avatar
wlkjr wlkjr is offline
I've never done mine in 9 years and 305,000 miles. I think I'm overdue though.
97 Grand Prix GT
360,000 miles as of 02-01-09
391 000 miles as of 11-17-11
400,000 miles as of 3-15-13
01 Duramax/Allison
07 G6 convertible
Old 04-13-2006, 06:01 PM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
you THINK you're overdue?!?! Now THAT'S funny!!!!
Still waiting for the "good old days" I'll get to bore my future grandchildren with!
Old 04-13-2006, 06:06 PM
J2done1133 J2done1133 is offline
Send a message via AIM to J2done1133 Send a message via Yahoo to J2done1133
hahaha, how do you change it if you wanted to do it yourself. is it recommended if you know how how to do a basic tune-up on the engine or should that be left to the ase certified guys.
Old 04-13-2006, 06:07 PM
BNaylor's Avatar
Sounds like a good way to finance a beer budget..lol.
All the money saved on lack of maintenance will buy a lot of beer. I'd have to flip a coin.
Timeslip 08/12/06
Old 04-13-2006, 07:48 PM
wlkjr's Avatar
It's one of the few things I neglect.
97 Grand Prix GT
01 Duramax/Allison
07 G6 convertible
Old 04-13-2006, 09:40 PM
sirul's Avatar
sirul sirul is offline
Here is a nice link on how to replace a fuel filter, hope this helps !!
http://www.pfyc.com/supportfiles/gasfilter/
1998 GMC Jimmy 4X4
1999 Grand Prix GTP (Nice!!)
2001 Saab 9-5
Old 04-14-2006, 10:45 AM
Langning Langning is offline
Originally Posted by sirul
I found it easier to disconnect the plastic-end first (then slide out the metal bracket) and then use wrench(es) to loss the metal-end...
Old 04-14-2006, 12:35 PM
hey sirul thanks for the post man. im on pfyc so much i cant believe that i hadnt seen that . haha.
Old 04-14-2006, 11:41 PM
Niq Niq is offline
Does the engine run kinda wacky for a while, after disconnecting the battery for this filter change?
02 GTP 2dr - HD sway bars, 18" wheels, 11.9 front rotors, Aluminum Trans oil pan,.... More mods are bound to happen.
Old 04-14-2006, 11:50 PM
BNaylor's Avatar
What do mean mean by run whacky after disconnecting the battery? Is this after the filter has been replaced. I never have any startup problems after replacing the fuel filter. It is a good idea to take the ignition to the run not start position several times so the fuel pump primes properly before actually firing it up.
It may take a few seconds of engine turnover and start after disconnecting the battery, however, on subsequent startups it should fire up OK.
Timeslip 08/12/06
Old 04-15-2006, 09:01 AM
Niq Niq is offline
I‘ve had previous experience with one of my older cars (Chevy Elcamino)….. when the battery was disconnected, the pcm lost the most recent “calibration” (lack of a better word) data, and it took about 10 or 20 miles for the engine to run like it used too… Or am I over here in left field….
Old 04-15-2006, 09:19 AM
BNaylor's Avatar
Normally not on odb-ii cars. Disconnecting the battery really doesn't do much and won't even put the PCM in relearn mode. It won't reset DTC error codes or clear the SES light either. The crank position angles are permanent and don't change with a battery disconnect either. I swap out between DHP and Intense PCMs all the time and never have problems like that.
If you get driveability problems like misfire or whatever after disconnecting the battery then something is not right.
Timeslip 08/12/06
Old 04-16-2006, 08:58 PM
sirul's Avatar
Glad it help , it happens all the time!!!
1998 GMC Jimmy 4X4
2001 Saab 9-5
