Go Back   Automotive Forums Car Chat > Jeep > Wrangler
Old 04-10-2006, 06:23 PM
wilson05's Avatar
wilson05 wilson05 is offline
Send a message via ICQ to wilson05
Adjusting valves on a 95 yj
hows it goin guys... i'm pretty sure i'm right on this one but i'd like verification before i go to tightening my valves.... when i start my jeep(2.5L) the valves tick for a little while then i guess when they finally get enough oil on them there less noticible .... does this mean i need to get them adjusted? and also might be related but is there a reason that near the end of my air filter line theres oil building up around the part where the line hooks up to the throttle body ... not much at all but it is noticeable i asked my friend and he said its probably the valves where they need adjusting... he told me his old beetle did the same thing then he had them adjusted and it quit... i know i shouldnt compare a jeep to that but i'd say i can in this case thanks for the help
Old 04-12-2006, 12:36 PM
fredjacksonsan's Avatar
fredjacksonsan fredjacksonsan is offline
Caution: Monkeys bite!
Send a message via AIM to fredjacksonsan
Re: Adjusting valves on a 95 yj
You have hydraulic valve lifters in your 2.5L, and they do not require adjustment. Last time I adjusted valves was on my 1974 Plymouth Scamp 225 slant six.
Just wait for the ticking to go away each time you start up. Make sure you are changing your oil regularly. My '97 had a 2.5 and it made some noise when first starting up.
Ours: 2020 Jeep Wrangler 2.0, 53k
2013 Toyota FJ Cruiser, 84k
Kids: 2005 Honda CRV, 228k
Old 04-13-2006, 01:23 PM
myjeepsux420 myjeepsux420 is offline
Send a message via MSN to myjeepsux420
If there is oil on the air filter, you have a blow by problem. Means the rings in the engine are worn out.
1995 Jeep Wrangler
3 1/2" lift 33x12.50 tires
4.5L stroked I-6
Bored throttle body & Cold Air Intake
Jet Chip Stage 2
Jet Thermostat
Colorado Off Road Rig!!!
