Go Back   Automotive Forums Car Chat > Nissan > Cedric | M45 | J30 | Gloria
Old 04-10-2006, 06:13 PM
supersnake83 supersnake83 is offline
ABS Light
Hi everyone,
My ABS light is on in my car and the ABS motor still runs when the car is off. On the fuzzycats website, it is indicated that the problem is with the ABS relays.
On the website there is a picture. Does anybody know how to remove the black case where the relays are?
Here is the link: http://www.fuzzycats.com/docs/ABS_indicator.pdf
Thanks,
Geoff.
Old 04-10-2006, 11:03 PM
swimshark swimshark is offline
Send a message via AIM to swimshark Send a message via MSN to swimshark
Re: ABS Light
funny thing...that has happened to me recently. I found out that if you remove the cover to the black box as indicated on the fuzzycats website. then pull the ABS sensor out (the one they have pictured), blow on it and in the box, then you put it back in. the light should turn off the next time you start up your car. my ABS light would come on after I'd hit a big bump and I guess it would jar the sensor loose. mine also vibrated even after the car was off. just follow the above and it should fix your problem. if it doesn't fix it you should then have it professionally checked out.
-Josh
