Old 04-10-2006, 05:43 PM
brass_monkey93 brass_monkey93 is offline
LT1 vs. LS1
I am going to be helping my friend redo an Opel GT. His plans are to put a small block Chevy into it, most likely a 350. I am mainly a body guy and don't know much about engines, and he is mainly an import guy that doesn't know anything about American engines. Basically what would help us out is if you guys could give us some of the major differences in the two engines. I know some such as the LT1 was Iron and the LS1 is aluminum. any information you can give is very welcome.
Thanks,
DJ
Old 04-10-2006, 05:55 PM
doodad's Avatar
doodad doodad is offline
Send a message via AIM to doodad Send a message via Yahoo to doodad
Re: LT1 vs. LS1
curtis can give u the uinfo about LS1
John can give u infos about LT1
Old 04-10-2006, 06:47 PM
giddyup50 giddyup50 is offline
Re: LT1 vs. LS1
I'm a Ford guy, I can't tell you any differences but, I can tell you that given a choice I would take the LS1. OR JUST MAKE THE EASY AND BEST CHOICE AND DROP IN A FORD 5.0!!!!!!!!!!!!
Old 04-10-2006, 07:03 PM
Mr. Luos's Avatar
Mr. Luos Mr. Luos is offline
Firebird Guy
Re: LT1 vs. LS1
You have much to learn
1999 Pontiac Trans Am WS.6 #1747
Stock'ish'
Old 04-10-2006, 07:29 PM
xeroinfinity's Avatar
xeroinfinity xeroinfinity is offline
out saving the world
Re: LT1 vs. LS1
i personally would stick with the cast iron blocks, but since your redoing an Opel Gt, you may want the lighter Ls1 to keep the car light weight.
1999 Grand Am SS 3.4 OHV
Old 04-10-2006, 07:44 PM
doodad's Avatar
Re: LT1 vs. LS1
l agree
Old 04-10-2006, 10:24 PM
knight7's Avatar
knight7 knight7 is offline
Send a message via AIM to knight7
Re: LT1 vs. LS1
LT1 is a corvette engine and LS1 is a trans am engine! Thats all i can tell ya
If s0methin(g) matt3rz th3n itz da stuff dat iz und3r da ( h00d).
99' firebird 3.8 v6
Old 04-10-2006, 10:30 PM
Mr. Luos's Avatar
Firebird Guy
Re: LT1 vs. LS1
Sadly you are mistaken.
Both motors have graced both cars. Corvette, Trans Am, and Camaro.
Stock'ish'
Old 04-10-2006, 11:08 PM
knight7's Avatar
Re: LT1 vs. LS1
Yes. im still learning the good stuff! One day i will be all kool like you Mr Luos
99' firebird 3.8 v6
Old 04-11-2006, 02:13 AM
importeater38's Avatar
importeater38 importeater38 is offline
Send a message via Yahoo to importeater38
Re: LT1 vs. LS1
ill jump in here since luos seems a little bored with this typical newbe thread.
genII/Lt1's have been in a variety of cars. 93-97 camaro/transam/formula, 92-96 (96 was lt4) corvette and impala 94-96, buick roadmaster 94-96 and cadillac brougham in 96
LS1/genIII --camaro/transam/formula 98-02, 97-01 vette i believe.
lt1s are reverse flow cooling, opti spark (pancake) distributer, hydraulic roller cam, belt less water pump, longer cylinder bore casting then gen I engines.
lt1s had aluminum heads in 92/93 and iron in 94-97 though there are some varients floating around.
lt1 block is iron, ls1 aluminum
lt1 intake is aluminum, ls1 is composite
lt1 has a higher torque to hp ratio then the ls1
So even tho its slower stock....it'll still snap your head back from a dig and bangin the next 3 gears
so yeah u can see im an LT1 guy....sorry i don't know more about ls1's, im still learning just like all the rest of us here.
93 trans am hurst shifter and zo6 rims. 94 trans am GT. functional ram air hood w/k&n air box, ROH rims, toyo skins, Borla cat back SS, TB bypass, de-screened MAF, BBK underdrive pully, Mieziere electric water pump, spec stage III clutch. '06 Yukon Denali XL, black, loaded. http://www.cardomain.com/ride/711131
Old 04-11-2006, 02:36 PM
Re: LT1 vs. LS1
thanks, this will be enough to get us started
future mods:
Pacesetter Headers
Magnaflow Exhaust
Jet Performance Chip
Ram air hood w/ functional air box
Old 04-11-2006, 03:20 PM
doodad's Avatar
Re: LT1 vs. LS1
so which one are u guys gonna pick?
LT1 or LS1?
Old 04-11-2006, 04:01 PM
Re: LT1 vs. LS1
well since an Opel GT is a light car we are leaning towards the LS1, but it depends on what we can find at a junk yard somewhere here in Michigan
future mods:
Pacesetter Headers
Magnaflow Exhaust
Old 04-11-2006, 05:27 PM
Re: LT1 vs. LS1
good luck at the yards
People like me just buy them to hav around
I heard these guys are a good place to shop for engines and stuff.
http://cherry-auto.com/
Good Hunting my friend!
Old 04-17-2006, 10:56 PM
lt1andls1 lt1andls1 is offline
Re: LT1 vs. LS1
Thanks,
DJ
1st off forget everything everyone else here has told you about both cars as I have not seen one bit of good info from anyone who posted. The amount of ignorant posts on this site is so far beyond my comprehension.
If you guys arent sure about something dont post it. I could go thrue here and just tell you how ignorant each and every post is. But Im sure you guys didnt post to be Jerks so Ill clarify a few things for you.
Ok, Now for the engines. I have owned 4 LT1's and 2 LS1's. There is no comparison. THe LS1 is simply 10 times better. I currently have both of them and My LS1 has a medium cam,clutch,stock 10 bolt with 4:10's,tune,Headers,SFC's and runs low 11's. All engine with stock heads all day. I trap 119 Consitantly.
My LT1 has heads,cam,stall,gears,and many other mods and My best trap to date on my current LT1 is 113 and my best quarter is 12.1 and I have 6k in it. I have 2300 In my LS1.
The Comment about LT1 making better power with displacment from the LT1 guy..Was a very ignorant thing to say. do some research before posting and if you dont know the facts please for the sake of those who are trying to learn dont comment.
LS1's have 340-350 HP stock and usually dyno 300 to the wheels in stock form. LS1's are a 346 CI motor. Less CID then the LT1 and makes over 50 More HP in stock form and quite a bit more torque as well. The LT1 makes very good torque at 2200RPM so people assume they make more torque. Not true.
LS1's can make 460 RWHP with cam only and stock heads. There LT1's with stage 3 heads and huge cams with 383 strokers that can swing this kind of power. There are LS1 head/cam packages that net around 550HP with stock Bottom end,na.
They are 2 completely different engines. The LS1 was built from a clean sheet of paper and is pure technolagy.
My LS1 ran a 12.9@107 stock with nitto's on the rear. My current LT1 was cammed with LT's and a tune before I could get a 12.9 out of it and with the hotcam, headers,gears,tune,stall,cai and a few other accenting mods I ran a 12.9@106
LS1:98-02 F-body,97-04 Vette.
And the comment about the 5.0..That one made my gut hurt.
If you can find a good deal on an LS1 buy it and be done with it. I have modded every car I have ever owned and thats a pretty large number of cars. I have had mustangs,Camaro's,TA's,ect.
