Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 04-10-2006, 05:00 PM
blk_srt's Avatar
blk_srt blk_srt is offline
Send a message via AIM to blk_srt Send a message via MSN to blk_srt
Exclamation big problem and I need help
Well Alot of you have kept up with my posts on my car and if any of you remember in my last post I said it was running pretty shitty and I thought it was the untuned 550s. Well I threw in some 450s today and The plan was to just drive it with those untill I got a wideband and then throw the 550s back in. Well it ran almost exactly the same with 450s and the afc zero'd out as with 550s with a shitty tune. This leads to to think the problem is somewhere else in the fuel system, but all I changed was the filter. Basically it has bad throttle responce in netural and its super doggy under load. I could barly make it up a hill in first at wot. when I am crusing at 30 in thrid it runs perfect but if I give it any more gas the timing goes way retarded, at wot it went to -17 degrees(retarded). All I did for the record was a head job(grind valves and seats), got the head ported(mild), fmic, and a ported 16g. Thats all I changed. Any ideas?
2004 Flame Red SRT-4
|Audiobahn 1200Q|Rockford 602s|Jensen flip out dvd|
Mods:
Old 04-10-2006, 07:14 PM
blk_srt's Avatar
Re: big problem and I need help
Mods:
Old 04-10-2006, 09:07 PM
defiancy's Avatar
defiancy defiancy is offline
Stay classy San Diego
So it still drives shitty even out of boost?
1991 GSX 2.3 Stroker
Old 04-10-2006, 09:10 PM
blk_srt's Avatar
yeah, it seems to spit and spudder while boosting and is super doggy when not. The guys at tuners said to look for a crimped fuel line.
Mods:
Old 04-11-2006, 11:49 PM
blk_srt's Avatar
ok I figured out the ignition timing is really retarded and I cant figure why since you cant adjust base timing on a 2g. My thought is the knock sensor is decting a phantom knock so the ecu is retarding timing and you can watch the timing on my logget go from 22 advanced at idle to 14 retarded at wot and ideas?
Mods:
Old 04-12-2006, 10:10 AM
defiancy's Avatar
Why can you not adjust the base timing on the 2g? I don't know much about the 2g.
I would imagine that you could put it to TDC and adjust the timing that way?
Maybe your CAS is fubar
Old 04-12-2006, 11:36 AM
blk_srt's Avatar
on a 95 the cas sits behind the intake cam gear and is in a fixed location therefore you cant adjust base timing with it. The sensor itself is brand new.
Mods:
Old 04-12-2006, 01:10 PM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
Make SURE the timing marks are lined up.
95 Talon TSI AWD
97 Eclipse GST
Old 04-12-2006, 01:12 PM
blk_srt's Avatar
I am 100% sure that they are lined up perfect
Mods:
Old 04-12-2006, 01:14 PM
Hm....weird. Maybe Kevin will come around and give some input, I'm fresh out of ideas.
95 Talon TSI AWD
97 Eclipse GST
Old 04-12-2006, 01:17 PM
Put on a fuel pressure gauge and check it under different loads. Idle, half-throttle, under power.
95 Talon TSI AWD
97 Eclipse GST
Old 04-12-2006, 01:36 PM
blk_srt's Avatar
already tried that. At idle its 45psi but since my car wont go faster than 30 mph and I cant boost and cant tell what it goes to then
Mods:
Old 04-12-2006, 01:55 PM
Well I'm thinking then it's somewhere else than fuel related. Better hope you got the angle on those valves perfect and your problem isn't occurring somewhere in the head after all that work. Other than that I don't know what to tell you.
95 Talon TSI AWD
97 Eclipse GST
Old 04-12-2006, 02:03 PM
crunchymilk55's Avatar
crunchymilk55 crunchymilk55 is offline
Send a message via AIM to crunchymilk55
sorry to ask again, but are you absolutely 100% sure the timing is lined up correctly???
now - 2000 civic
soon - 2002 is300
Old 04-12-2006, 05:22 PM
blk_srt's Avatar
checked and double checked. I guess it is possible that it maybe off but it would be a MAX of 1 tooth but I'm sure its dead on. I already did a leakage test and everything is sealed. As far as the fuel I've pretty much ruled it out. I know there is pressure getting to the motor and it is possible that there isnt enough volume but I didnt change anything with that so I dont see how it all the sudden changed
Mods:
