Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 04-10-2006, 04:52 PM
baddass4444 baddass4444 is offline
Exclamation Car Dies overnight... please help
Hello everyone, thanks for all who read and help me out here!
FOr about 2 weeks now my car gets charged and dies overnight. I have an Amp hooked up, but I have checked all the wires, and even rewired the whole thing. The power wire is covered so it's not touching anything hot. I was assuming that this was the problem, but I don't think it is anymore. What else could be draining the power? Anyone have any ideas or have had similar problems?
thanks for any help!
Old 04-10-2006, 05:39 PM
l_eclipse_l's Avatar
l_eclipse_l l_eclipse_l is offline
Re: Car Dies overnight... please help
Could it be that your battery is just dead? Do you have a remote wire hooked into your head unit so the amp shuts off when the car is off?
'92 3000gt SL
Zoom Stage 1 Clutch
Originally Posted by kjewer1
I disagree. Better is better. Bigger is just bigger.
I just made that up, and I like it.
Old 04-10-2006, 06:01 PM
I do have a remote wire hooked up.
Also the battery is only about 5 month's old, I don't think it's the battery, but i guess it could be.
Old 04-10-2006, 07:12 PM
blk_srt's Avatar
blk_srt blk_srt is offline
Send a message via AIM to blk_srt Send a message via MSN to blk_srt
You have a parasitic draw somewhere. To test it you need a multimeter and you put it in series between the ground wire and the negative battery termanal and basically start pulling fuses untill you can figure out whats staying on. Obviously there is alot more to it and if you cant find any info on it let me know and I can go into more detail as I'm sure many others here can also
2004 Flame Red SRT-4
|Audiobahn 1200Q|Rockford 602s|Jensen flip out dvd|
Mods:
Old 04-13-2006, 02:39 PM
Ok, how exactly do you go about using a Multimeter?
Old 04-13-2006, 03:41 PM
-Josh-'s Avatar
-Josh- -Josh- is offline
Automotive love doctor
Send a message via AIM to -Josh-
Set it to ohms, put between negative power cable and negative post, remove fuses.
I would have someone who knows what they're doing check it out but if you're confident you can do it go for it.
Self improvement is masturbation
AF User Guidelines
What is a mippie? - click
Old 04-13-2006, 04:33 PM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
This should be obvious but your remote is hooked to the back of the deck right and not the battery?
95 Talon TSI AWD
97 Eclipse GST
Old 04-13-2006, 05:08 PM
I thought I already asked this....
'92 3000gt SL
Zoom Stage 1 Clutch
Old 04-13-2006, 08:32 PM
I know he said he did have a remote wire hooked up but he didn't specify where, I'm just making sure it's in the back of the head unit and not the battery, which could cause the battery to die overnight.
95 Talon TSI AWD
97 Eclipse GST
Old 04-14-2006, 12:14 PM
Give me a little credit here, my remote wire is hooked to be the back of the Stereo unit.
Gesh!
