Old 04-10-2006, 03:06 PM
tbuckit1's Avatar
tbuckit1 tbuckit1 is offline
Send a message via AIM to tbuckit1
Security 05 Caravan
I have purchased a used '05 Caravan. It has the keyless entry fob built into the key and I have two keys. The keyless entry system works on both keys, but one key is not programmed to bypass the security system. They both will lock and unlock the doors, but only one will start and run the vehicle. The other only lets the van run for a couple of seconds.
Is there a way to program the second key to start the van myself? or do I have to take it to the dealer.
Thanks in advance for your answer.
Old 04-10-2006, 08:06 PM
vipergg vipergg is offline
Re: Security 05 Caravan
Think you have to take it to the dealer and they have to program it . Don't know how much they will charge just to program it , if you have to buy one it like 80-90 dollars ..
Old 04-11-2006, 09:54 PM
xj31 xj31 is offline
it sounds like you might have a bad key.when it gets programmed,the remote and key part are both programmed at the same time.
Old 04-14-2006, 05:06 PM
tbuckit1's Avatar
Thanks for the input, I'll check that out.
Old 04-15-2006, 01:30 AM
Bernard Feltzer Bernard Feltzer is offline
You can program the key yourself for that model, the instructions are in the owner's manuel.
Old 04-15-2006, 10:39 AM
chryslertech8 chryslertech8 is offline
you can program the key yourself IF you have two good keys that are programmed. other than that you have to go to the dealer and they can program this key (if the built in transponder is ok). programming should only cost about 50-60 bucks.
good luck!!
Old 04-15-2006, 01:39 PM
cbwilsha cbwilsha is offline
The vehicle is still under warranty so why NOT take it to the Dealer? There should be no charge to "fix" the second key. If they do charge you, I would contact Chrysler regional hq and complain. BTW, I have a 05 T&C.
The info given earlier is correct that 2 correctly operating keys are required to program a third by the owner but a dealer can program it.
C.B.
Old 04-18-2006, 09:48 AM
tbuckit1's Avatar
Thanks for all the response. This van came from Avis and I'm sure the key was added after the second was probably misplaced. I may get my local dealer to program it under warranty. It's worth a try.
