Old 04-10-2006, 12:21 PM
busa4 busa4 is offline
rear differential specs needed.
hello all. i am replacing my ring and pinion and i cant seem to find any specs on setting up the dif. does anyone know what backlash (back and forth movement when holding pinion gear and moving ring gear) i should look for when setting up the ring gear on the pinion gear? i dont want to just look at the contact pattern. i will feel better about this installation when i get a good backlash measurement from my dial indicator....
thanks all.
Old 04-17-2006, 11:12 PM
bigd7315 bigd7315 is offline
Send a message via Yahoo to bigd7315
Re: rear differential specs needed.
.003 but white lithium grease works well
Old 04-18-2006, 03:44 AM
RahX RahX is offline
also good to check :
PINION BEARING AND DIFFERENTIAL BEARING PRELOAD
Pinion and Differential Case Bearing Preload;
New Bearings 3.4 - 6.2 Nm (30 - 55 lb. in.)
Used Bearings 2.8 - 5.1 Nm (25 - 45 lb. in.)
Pinion Bearing Preload;
New Bearings 1.7 - 3.4 Nm (15 - 30 lb. in.)
Used Bearings 1.1 - 2.3 Nm (10 - 20 lb. in.)
Old 04-19-2006, 08:11 AM
0.003" are u sure? that is pretty tight. i was thinking .010-.012"
Old 04-19-2006, 11:22 PM
dmbrisket 51's Avatar
dmbrisket 51 dmbrisket 51 is offline
Send a message via AIM to dmbrisket 51
.003 to .005 for our trucks, its very tight new, im not sure on 'throw away' speck, but that is much looser then the 3-5 thou. you started with
Old 04-20-2006, 09:46 AM
i found the spec from a ring/pinion company i searched on google. spec for backlash on a 7.5" 7.625" ring gear for street use is .008-.012"
thanks all for your help guys...
Old 04-22-2006, 08:58 PM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Here is a link that has so good info.
http://www.differentials.com/install.html
MT
MT
