Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 04-10-2006, 12:14 AM
mitsutuner13 mitsutuner13 is offline
Send a message via Yahoo to mitsutuner13
wont start after timing belt replacement
a couple of weeks ago i replaced my timing belt and the first time i put it on, i started the car *when the timing was off a little, like 2 degrees* and it ran like crap. so i reset the timing belt. now the timing is perfect as far as i know. now the car wont even start. could i have messed something up with the timing just being off a little? what could be wrong here?? any suggestions?
mitsutuner13: 96 mustang GT ....i have steeda lowering springs, k&n cone filter w/ adapter, Mac X-pipe with dual chamber flow masters.
Old 04-10-2006, 12:15 AM
Re: wont start after timing belt replacement
by the way *sorry* this car is a 95 eagle talon TSI. its mostly stock.
Old 04-10-2006, 12:30 AM
ez1286's Avatar
ez1286 ez1286 is offline
Send a message via AIM to ez1286
Do a compression test. I'm not sure if 2 degrees is enough but you may have bent valves...
95 GSX:FMIC, 6-bolt, evo 3 16g, 2600 act clutch, 1g bov (crushed), and a 3" turbo back exhaust, dsmlink, dks 272 cams, wideband 02, Coming soon 2.3L Stroker, 1mm oversized valves, crower sprigs. 91 TSI AWD auto, gm 3.5 maf, maft, fmic, emanage, profec e-01, 3" turbo bk exhaust +more little stuff.
http://www.ratemydsm.com/member/ez1286/?member=ez1286
Old 04-10-2006, 12:33 AM
i will do that tomarrow. thanks. ill keep you posted on how it goes. OH YEAH!! when i started the car with the timing off, i did hear a clank noise, but at the time i thought it was a pulley making noise....i bet that was a valve i heard. definate compression test tomarrow.
Old 04-10-2006, 12:35 AM
ez1286's Avatar
eeek sounds bad. I'm sorry but it sounds like you will have to rebuild your head.
Old 04-10-2006, 05:49 AM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
I'm betting some valves went bendy-bendy. Have fun with that.
95 Talon TSI AWD
97 Eclipse GST
Old 04-16-2006, 11:12 PM
compression check seemed ok, i am going to try to set the timing again.
Old 04-19-2006, 12:36 AM
E-Klips E-Klips is offline
Banned
What was the results of the compression test... like numbers?
Old 04-19-2006, 12:48 AM
150
Old 04-19-2006, 11:18 AM
l_eclipse_l's Avatar
l_eclipse_l l_eclipse_l is offline
Originally Posted by mitsutuner13
150
Ok....what about the other 3 cylinders?
'92 3000gt SL
Zoom Stage 1 Clutch
Originally Posted by kjewer1
I disagree. Better is better. Bigger is just bigger.
I just made that up, and I like it.
Old 04-20-2006, 09:57 AM
Black97GST Black97GST is offline
LOL! yeah i seriously doubt you had exactly 150 across the board? there had to be at least a LITTLE fluctuation.
Old 04-20-2006, 02:20 PM
I'm still banking on my first assumption that the valves went bendy-bendy.
Ok this may seem like a stupid question, but you're lining up all the marks right, not just the cam gears?
95 Talon TSI AWD
97 Eclipse GST
