Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 04-09-2006, 06:53 PM
Archangel97 Archangel97 is offline
95 eclipse sunroof is stuck open. Please Help
My sunroof is stuck open. When i push the button I hear a loud click, but no movement. The sunroof will wrk some days and not work for some days. What could it be?
It is supposed to rain today, so more immediate, how do I close the sunroof with an allen wrench?
Sunroof- up down
Moonroof- slide back slide forward
I have a sunroof.
Please help, I appreciate it.
Old 04-09-2006, 07:42 PM
crunchymilk55's Avatar
crunchymilk55 crunchymilk55 is offline
Send a message via AIM to crunchymilk55
Re: 95 eclipse sunroof is stuck open. Please Help
have someone push the button while you force it in and guide it through the rails. If it works sometimes, then the motor is probably still fine, just the rails are bent.
now - 2000 civic
soon - 2002 is300
Old 04-09-2006, 08:17 PM
Thank you for the advice, but that did not work. WHat else can I do?
Old 04-09-2006, 08:36 PM
When I push the button I don't hear the motor running, I just hear a loud click like the motor wants to work
Old 04-09-2006, 09:43 PM
ned032002's Avatar
ned032002 ned032002 is offline
Sounds like the gears aren't making contact, is there anyway you can get to the motor to see if this is happening?
Old 04-09-2006, 10:53 PM
L-Spec's Avatar
L-Spec L-Spec is offline
Send a message via MSN to L-Spec
..or maybe a wire's loose, lol. I couldn't figure it out, until I heard it was going to rain too, so that gave me the motivation I needed to find the problem for five hours.
Anywho, down at the base of your steering column, on the left side where your knees might be, there's going to be some wires. It'll be the red one, I believe. Push the wire in so it is secure and try that. That was the problem with my sunroof. If that doesn't work, I suggest you invest some money for a garage
1992 Ẽfini RX-7 FD3S
