Go Back   Automotive Forums Car Chat > Honda > Civic | CRX > '96-'00 Civic
Old 04-09-2006, 05:34 PM
justinwebb justinwebb is offline
Send a message via AIM to justinwebb
00 civic low idle
every time i come to a stop my car idle drops below the little line right above the 0 rpm line and the car shakes and almost dies.....i have done tune up which was plugs, wires, cap and rotor...also changed the pcv valve still doing the same thing any ideas on what to check next or any suggestions?
Old 04-11-2006, 03:05 PM
batman19 batman19 is offline
Send a message via AIM to batman19
Re: 00 civic low idle
my car doing the same, it went away after warm up, but still rough at idle
1997 Civic HX
1.6 D16Y5 engine
Auto with 55K
STOCK
Old 04-17-2006, 08:26 PM
wakeboard_dude5 wakeboard_dude5 is offline
Send a message via AIM to wakeboard_dude5
Adjust your idle screw, its right on the throttle body close to the throttle opening. http://www.team-integra.net/sections...?ArticleID=195 <-- has a pretty good pic of where its at
1993 civic EX coup auto SOLD! but i'll miss her
1996 Civic CX w/ B18c1 swap, small bolt on's, 2000 front end
Old 04-22-2006, 01:02 PM
silvrcvik silvrcvik is offline
i had a new engine replacement done about 9 months ago, and my idle was dropping low. so i got worried, my mechanic said try cleaning the air intake. I sprayed some cleaner in started it up, it coughed choked for like 3 seconds now it idles perfectly.
Old 04-27-2006, 09:21 PM
gmcuajo gmcuajo is offline
The MIL (check engine light) is on. It have any code.
As the other reply says, clean it with a "throttle cleaner spray". Remove the IACV (idle valve) and clean it, sometimes this valve have dirt and carbon on it. Check the gaskets and/or o-rings
As I understand, is the PCV have leakage the RPM's goes up.
