Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 04-09-2006, 02:58 PM
Studly08 Studly08 is offline
Question Help...Soon as possible :(
Wassup i own a 93 eclipse Gs with dual O Cams (crower) and i need help with starting my car. Sounds stupid right ? Well Surley its not i started my car up right after i got it from my mechanic started fine seamed to be tempted not to though yet the same it still started. Next day my friend came over to hear it went in there saying oh its sweet this and that and it didnt start any ideas just had the fuel pump replaced followed by the ecu. My car trys to start but all it does is turn over..... no spark .... just got new plugs and wires.... Suggestions please..... no car = no job ...... no job = no money
Thanks feel free to email me at [email protected] also if you dont have an AF account.
Old 04-09-2006, 03:37 PM
blk_srt's Avatar
blk_srt blk_srt is offline
Send a message via AIM to blk_srt Send a message via MSN to blk_srt
Re: Help...Soon as possible :(
Have you checked the coil?
2004 Flame Red SRT-4
|Audiobahn 1200Q|Rockford 602s|Jensen flip out dvd|
Mods:
Old 04-10-2006, 12:21 AM
Talking Re: Help...Soon as possible :(
No I havent autozone said it might be the coil also just needed some reassurance ill get it with my next paycheck and tell you.
Thank you also
also if anyone else has any possible solutions id appreciate help from anyone
Old 04-10-2006, 12:28 AM
ez1286's Avatar
ez1286 ez1286 is offline
Send a message via AIM to ez1286
I would try to find a used coil considering you don't know that's it for sure. Check cas (cam angle sensor) and also the ecu. I know you said it was just replaced but check to make sure all the connectors are on tightly.
95 GSX:FMIC, 6-bolt, evo 3 16g, 2600 act clutch, 1g bov (crushed), and a 3" turbo back exhaust, dsmlink, dks 272 cams, wideband 02, Coming soon 2.3L Stroker, 1mm oversized valves, crower sprigs. 91 TSI AWD auto, gm 3.5 maf, maft, fmic, emanage, profec e-01, 3" turbo bk exhaust +more little stuff.
http://www.ratemydsm.com/member/ez1286/?member=ez1286
Old 04-10-2006, 06:20 AM
Exclamation Re: Help...Soon as possible :(
When You Are Talking About Coils Your Talking About The Coil Pack Right ?
Old 04-10-2006, 06:30 AM
bonedavid's Avatar
bonedavid bonedavid is offline
coils are a possibility...also check the tdc sensor (top dead centre) or crank sensor.
this caused my renault to give up the ghost.
cheap to buy and easy to install ( at least on a laguna)
hope this helps
Old 04-10-2006, 11:19 AM
l_eclipse_l's Avatar
l_eclipse_l l_eclipse_l is offline
Yes, that's what he was referring to.
Try not to capitalize every word in your sentence.
'92 3000gt SL
Zoom Stage 1 Clutch
Originally Posted by kjewer1
I disagree. Better is better. Bigger is just bigger.
I just made that up, and I like it.
Old 04-10-2006, 03:30 PM
Wink Re: Help...Soon as possible :(
Bad habbit sorry ...... <---- Had to restart because i did it again *Laughs*.
With these ideas i will try friday when i get my check and ill update for you if you all are still willing to help.
Old 04-10-2006, 04:11 PM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
Check the crank sensor before you go and replace the whole coil pack. The crank sensor is on the back of the block next to the oil filter housing. Be careful when you take it out though, if it breaks you'll be spending about 2 hours trying to fish it out of there.
95 Talon TSI AWD
97 Eclipse GST
Old 04-10-2006, 11:04 PM
Thumbs up Re: Help...Soon as possible :(
Many thanks Do you have a picture of what it looks like ? looked on auto zone, and no crank sensor only "ANGLE SENSOR - CRANKSHAFT" anyluck on any other names please i would appreciate it.
