Old 04-09-2006, 10:30 AM
3mikeman 3mikeman is offline
engine codes
Does anyone know how to get the codes without using a scanner i know on the old fords you can use the jump wire but mine is the new style 1993 escort gt 1.8l. The check engine light will stay on for about 1 or 2 minutes after first started i just repalced the oxygen sensor pulled the negitive off the battery for 5 minutes check engine light still comes on.
Old 04-10-2006, 01:13 PM
mightymoose_22's Avatar
mightymoose_22 mightymoose_22 is offline
Re: engine codes
Look here for a way to use a jumper wire... you can either watch the codes flash out on the dash or with a voltmeter as in the diagram.
http://www.corral.net/tech/maintenance/eecivtest.html
