Go Back   Automotive Forums Car Chat > Dodge > Ram Pickup | Ram SRT10
Old 04-09-2006, 10:02 AM
butchsterling butchsterling is offline
Dodge ram 50 trans fluid?
What type of transmission fluid do you put in ram 50 trans? It does not say on dipstick.
Old 04-09-2006, 03:07 PM
Stevo2's Avatar
Stevo2 Stevo2 is offline
Re: Dodge ram 50 trans fluid?
you don't mention a specific year so I will say ATF+3
Jack of all trades...Master of none!
Could someone please fix my Instant Email Notification?
Please get back to us with your fix!
Why did you buy a $40K vehicle and not a $100 Factory Service Manual?
Old 04-09-2006, 06:15 PM
edbrycem edbrycem is offline
ATF +4 will probably work too since that is better
Old 04-12-2006, 10:38 AM
fredjacksonsan's Avatar
fredjacksonsan fredjacksonsan is offline
Caution: Monkeys bite!
Send a message via AIM to fredjacksonsan
Year and engine will make a difference I think.....
Ours: 2020 Jeep Wrangler 2.0, 53k
2013 Toyota FJ Cruiser, 84k
Kids: 2005 Honda CRV, 228k
Old 04-12-2006, 10:45 AM
I think the only dirrerence really is that atf +4 is full synthetic, I dont think the other ones are. I could be wrong though.
Old 04-12-2006, 03:18 PM
neon_rt's Avatar
neon_rt neon_rt is offline
Aren't RAM 50's from the early 80's and have a 904 trans (auto)?
In that case you could probably use Dextron/Mercron.
I would recommend ATF+3 though.
There was a bulitin regarding newer 3-speed autos up to '99, recommending not using ATF+4. I think it may be "to slick" (friction modified) for those transmissions.
Old 04-12-2006, 04:26 PM
I thought all newer came w/ OD which would be 4th gear. i read somewhere to use the atf +4 in my 98 cuz it was an upgrade from prior atf. because it is full synthetic. i hope
Old 04-12-2006, 05:39 PM
neon_rt's Avatar
RAM 50's are built by Mitsubishi and I think the newest ones are from around '91 or so (dis-continued model). The ATF+ series was originally developed for the "UltraDrive" fwd 4-speed auto that came out around '91 or so.
Old 04-14-2006, 02:32 PM
It's a 1987 with a 2.6 litre Mitsubishi.I don't have owners manual and it doesn't say on dipstick. Thanks for all the replies.It does have overdrive.
Old 04-15-2006, 06:43 AM
Amsoil ATF should work for you; I wasn't able to find any other reference. However in that year, you had basically Dexron/Mercon and Fort type F ATF fluid. If you're not going synthetic, my vote would be for the Dexron.
