Go Back   Automotive Forums Car Chat > Ford > Contour
Old 04-09-2006, 09:57 AM
hip_checker hip_checker is offline
Lightbulb 2.5L V6 Stalling in Cold Weather Sollution
Hi everyone,
I was just looking around the forum and couldn't help but notice that a lot of people are having the problem I was having.
My car would always stall when it was really cold outside. I would start it and would have to sit in it and hold the gas pedal down to get the RPM up.
Well turns out I had a leak in the intake manifold gasket. What I did to find the problem was to have someone sit in the car and press the gas pedal. Then I went around the engine with carb cleaner and sprayed everywhere around the intake manifold where it met with the gasket. If you have a leak the car will want to stall when you spray where the problem is. I replaced both upper and lower intake gaskets since I had it all apart. Both gaskets cost around $100 Canadian.
It's been over two years now and the problem hasn't happened since. I live in Canada and I've been in -40C weather and the car runs like a charm.
Hope this helps.
Old 04-09-2006, 11:10 AM
beyondloadedSE's Avatar
beyondloadedSE beyondloadedSE is offline
AF Ford Contour-Advisor
Re: 2.5L V6 Stalling in Cold Weather Sollution
good to hear you got it figured out.
check out contour.org.
Every single problem known to man has been discussed over there. Theres also how-to's (i.e. intake manifold gaskets) that are discussed in the FAQs for future reference.
"The CEG Nazi"
www.contour.org
1996 Ford Contour SE - Sold
3.0L V6 and Arizona Dyno Chip Turbo Kit
364 whp, 410 wtq @ 16 psi and only 4,700 rpms.
1999 Tropic Green SVT Contour - Bone stock and MINT
