Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 04-09-2006, 02:14 AM
Eagalicious's Avatar
Eagalicious Eagalicious is offline
A question on exhaust if I may
I am following the Buschur upgrade sequence and am a little confused. I hope you guys can help me out. Step 2 is this:
2. Cat-back Exhaust System
AWD with 12 or 13 sec goal:
Buschur Racing 2.5" Pressbent Aluminized piping with Stainless Muffler and 4" Polished Tip - 1G or 2G (AWD Only)
All Turbo FWD or AWD with sub-12 sec goal:
Buschur Racing 3" Mandrel Bent Stainless piping and Muffler with 4" Polished Tip - All Turbo FWD and AWD Models
Now I have read a few posts and people say that it is best to do a turbo back. If i understand correctly, that is a down pipe all the way back. I also read there is a 2.5 and 3*. My question is this: Will I have to make any modifications to fit a 2.5 or 3" down pipe to my turbo or does the down pipe fit connect fine from the flange then goes to 2.5 or 3' from there?
I also read that if I use a 3" that I could get boost creep I have to look boost creep up again but it doesn't sound good. What would be the best muffler to use? I have listened to HKS systems and they sound nice. I don't want the loud sound I hear the kids using around here. I also wanna keep my dual tips if that is possible.
Buschur says do the down pipe at stage 2 of the upgrade.
Any advice would be appreciated guys. I was told I would feel an increase in power a little bit. Hey... I have to start somewhere
Thanks in advance guys
Eagalicious's
1997 Eagle Talon Tsi AWD
K&N FIPK
3rd gen lifters, installed
Apexi Turbo Timer w/harness!!! now to install
Eibach Springs coming soon
3" turbo back with straight pipe.
The muffler was the wrong one
Manual BC
1G BoV
The rest is stock but not for LONG!!
Old 04-09-2006, 02:27 AM
crunchymilk55's Avatar
crunchymilk55 crunchymilk55 is offline
Send a message via AIM to crunchymilk55
Re: A question on exhaust if I may
thank you for doing a bit of research first. when it comes to exhaust components you forgot one thing. The turbo connects to the 02 housing, the 02 housing connects to the downpipe. The 02 housing can accept 2.5 or 3 inch, it doesn't matter, they both fit. I suggest the 3" exhaust, and just port the turbo and manifold, there are threads on how to do this already. Also when people mention a turbo back exhaust, they usually mean an 02 housing as well, you can get 02 housing's that flow better than stock, or just port yours.
now - 2000 civic
soon - 2002 is300
Old 04-09-2006, 03:25 AM
Can I add the components and port later?
Eagalicious's
K&N FIPK
Manual BC
1G BoV
Old 04-09-2006, 12:59 PM
MexRocket's Avatar
MexRocket MexRocket is offline
You could just not worry about the 02, and just make the exhaust come right off the turbo, and drille and tap a hole for the 02 sensor. Right? you could make it 3" all the way off the turbo. Stock turbo as in the A/t Turbo or the M/t turbo, if you have the 14B turbo, i think the 3" all the way would be perfect for it. I don't know though.
STATUS: Near completion for the Engine
PROJECT BEST 1G IN IL:70% Done
MODS: C2 boost,mbc,B16GEGTurbo,12x28x3x3 FMIC,Ported2gmani,k&n.
Being bought in two weeks: Dsmlink,880's,3"exhaust,piping,suspension,axel,dri lled and slotted brakes.
