Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Suburban
Old 04-08-2006, 11:26 PM
99k1500 99k1500 is offline
99 k1500 wont start
well i went to leave work and it just wouldnt start it trys to start but it wont fire it turns over real good so i pulled the pump and hooked it up to a 12v battery and it worked just fine i also got a new fuel pump relay and that did nothing It also made a lot of noise when you would shut the truck off from the fuel pump area i also did a quick check to see if i was getting any gas to the regulator and it wasnt.any ideas would be nice thanks.
Old 04-09-2006, 10:21 AM
maxwedge maxwedge is offline
A990 racer
Re: 99 k1500 wont start
Do yo have fuel pressure at the rail, step one in diagnostics.
Old 04-09-2006, 03:06 PM
no it has no pressure at the rail and the pump does not turn on when you try to start it.
Old 04-09-2006, 10:17 PM
bndfishing bndfishing is offline
use the relay by pass connector and apply 12v, also check the fuel filter a plugged filter will take the pump out if it is left too long. Use a test light and make sure you have 12v at the relay, both the enable side and the power side.
Old 04-09-2006, 10:59 PM
Boomyal Boomyal is offline
You haven't said whether you have spark or not. If not, you either need to replace the crank sensor or the igniter.
Old 04-10-2006, 04:36 AM
sorry yes i do have spark .
