Old 07-12-2002, 10:20 PM
branman_crx_guy's Avatar
branman_crx_guy branman_crx_guy is offline
Send a message via AIM to branman_crx_guy Send a message via Yahoo to branman_crx_guy
Hatch Squeaks, Kind of a Bitch.....Suggestions?
Hey, my hatch squeaks like a mo' and I cant figure out why. I used electrical tape before to fix most of the rattling, but I knew where this was coming from. I can't find the squeaking because its only around when I'm driving like 15-40 mph. Anyone have any ideas? Should I just wash my car in WD-40? I got plenty of it to go around. Any and all advice is apreciated, as usual. :frog:
Born 2/19/85: Thats right ladies, the BMan is Legal!! ;-)
Totallin My 89 CRX Si: +$2700
Buyin It Back From Insurance: -$50
Buying a 90 CRX Si: -$2200
Gettin to start over with more money and knowing i screwed insurance w/out trying: Priceless
It doesn't matter if you win by an inch or.........wait, thats been said already. On the road of life there are passengers and......no, thats been done too. Dang, all the good sayings have already been said, ohwell.
-BMan original
Old 07-12-2002, 10:35 PM
ci5ic's Avatar
ci5ic ci5ic is offline
worlds tallest midget
My passenger door used to squeak really bad, and everyone that rode in the car would say it was coming from a different area of the door (some said it was the top seatbelt mount, some said it was towards the lower front of the door). Anyways, I found out that it was the vinyl of the door panel rubbing on the metal frame of the door towards the b-pillar. What I did was fold up a piece of paper a few times and wedged it between the panel and the door as a temporary fix. Since I removed my panels before taking the car in for pain/body kit, I'm going to put somekind of permanent fix on.
Also, on your hatch, as well as the doors, there are several rubber stoppers that can be adjusted by twisting them. Unscrew them a little and see if that helps...
Old 07-12-2002, 11:04 PM
I already have the rubber stoppers out like most of the way on the doors and the hatch, it stopped some rattling, but no squeaking. Could it be the hydraulics for the hatch? Thanx for the reply, keep them coming, I'm trying to get all my little problems fixed in my car, and post-whoring at the same time (WIN WIN) :frog:
-BMan original
Old 07-12-2002, 11:36 PM
FourthGenHatch's Avatar
FourthGenHatch FourthGenHatch is offline
Send a message via AIM to FourthGenHatch
When I replaced my window I noticed under the door panel is a piece of plastic with caulk or something around it, that keeps water from getting to the door panel I guess, but it may also keep the contact of the panel and the metal from touching and squeeking also.
http://www.fourthgenhatch.com
FOR SALE: Get this stuff out of my house!
-Stock hood (red) $30
-Stock Rear Spoiler (red) $30
-Stock mirrors $30/both
-Stock side front and rear side glass $30/piece
Old 07-13-2002, 07:32 PM
Moppie's Avatar
Moppie Moppie is offline
Master Connector
Im pretty sure the latch can be adjusted on both the hatch, and the body.
Just peel back the plastic around it, there are two 12mm bolts on the body side of the latch. Lossen them off, and lower it a few mm.
Then close the hatch and go for a drive. see if it makes any differnce.
It might pay to wind in the stoppers first, then you can use these to make small adjustments.
Also as the rubber seal gets old it goes hard, and squekes, use some silicone spray or rubber conditioner on it. Or better yet replace it.
Old 07-13-2002, 10:57 PM
gunnmen01's Avatar
gunnmen01 gunnmen01 is offline
Send a message via AIM to gunnmen01 Send a message via Yahoo to gunnmen01
i thought i had a hatch squeak , but it turned out it was the rear vent windows were a lil loose, gues i didnt tighten them when i was tinting the windows.
gunnmen01
My other ride..... is YOUR MOM !!!!!!
Old 07-14-2002, 05:16 PM
RedRacerCivic's Avatar
RedRacerCivic RedRacerCivic is offline
Send a message via AIM to RedRacerCivic
My whole rear hatch squeeks like mofo, its kinda like a symphony in my trunk, i should record it and send it to a record company and make millions and go on tour. :silly2: I've traced it to be the rear shelf and that panel under the rear glass. So my solution to get rid of it.....play your music reaallly loud so it cancels out the squeeky squeeky.
-1991 Civic Si (Sold)
-1990 Accord EX(Sold)
-2000 Civic Hatch
-1998 Lexus SC300
Click here to see my Shoe!
