Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 04-08-2006, 09:54 PM
slavejay slavejay is offline
radiator
85 caprice 5.0 4barrel
need to install a new radiator before it gets hot out..... anyone try an aluminum (sp?) radiator and if so , is it worth the extra dough?
Old 04-08-2006, 10:43 PM
96capricemgr 96capricemgr is offline
Re: radiator
The Caprice needs no special attention to cooling because the radiator is so big it can't help but work well. Just get a quality replacement don't worry about "upgrading"
For what it is worth I am not a "keep it stock" guy either even though my answer sounds like I could be. To make that point today was spent pulling a modified engine out of my Caprice so I can do more to it, cooling is about the last thing that needs any upgrades.
Old 04-09-2006, 04:51 PM
TommySS TommySS is offline
Re: radiator
If I remember correctly, the stock radiator is a 2-row. I went to a 3-row, but had to modify the fan shroud and use upgraded rubber mounts.
Old 04-09-2006, 05:03 PM
Re: radiator
did you see any more performance out of the 3 row?
Old 04-09-2006, 06:29 PM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
Re: radiator
A couple of years ago, I replaced mine (due to a leak) with a 4-row truck radiator. This necessitated a move to a larger fan shroud/radiator mount (out of a 1979 Caprice). The hottest I've ever gotten it here in the Phoenix area was about 5 or so degrees more than the thermostat temp (it's a 195, so about 200 or so) on the hottest day last year. Needle-width left of midway on my 9C1 gauge set.
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
Old 04-09-2006, 07:53 PM
Blue Bowtie's Avatar
Registered Offender
Re: radiator
Ahh! No wonder it's so friggin' hot in Phoenix. You're pumping all that heat into the air!
Have yo noticed a longer warmup time on cooler mornings duel to the extra radiator capacity? I'm thinking that the latent heat of the system will take a little longer ot equalize with engine heat. Bet it stays warm a little longer, too.
Old 04-18-2006, 08:14 PM
Re: radiator
Warm up time is related to the T-stat operation, not a function of radiator size.
After all these years, the temperature light never came on until the t-stat stuck shut. I guess the 3-row bought me some time over the 2-row.
