Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 04-08-2006, 10:37 PM
Blackcrow64's Avatar
Blackcrow64 Blackcrow64 is offline
6 Bolt vs 7 Bolt
Alrighty... I've been doing a lot of reading and have heard many opinions on this. From what I can tell, people have completely blown the whole "7 bolt is worthless" theory out of proportion. I have read how the 7 bolts are designed so much better but the only problem they have is the higher possibility of crankwalk. (I know all about that. )
Anyways, I have been looking for the most common "fixes" for crankwalk. The biggest theory is the thrust bearing failure theory. I haven't heard of any other possible causes for crankwalk though. So heres what I'm thinking... If I decide to build a 7 bolt using clevite bearings and a synthetic oil, I should have no problems with crankwalk. The one thing I've been searching for is how many people have built their 7 bolts though and I can't seem to find vey many at all...
I guess what I really want in this thread is opinions on this very subject. It would be a lot easier to just keep my 7 bolt and build it and put it back in my car. But I fear spending thousands of dollars on a motor only to have it crankwalk again. I could go the 6 bolt route but then I would have to rewire my CAS and change a few other little things and I would probably have more money in that route than I would the 7 bolt...
Oh yeah, the compression ratio... Thats another thing that I wondered about. I have read that the 1g's have a compression of 165 and the 2g's are 190. With the lower compression you can run more boost before worrying about detonation, right? But, with higher compression (190) your turbo will spool quicker and be more efficient in its power building?... Another plus to the 2g's is the heads can be more efficient than 1g's if ported out?...
I just wanna make sure I cover everything on here with you guys before I start buying things. I would hate to do this wrong and have to redo anything... Thanks for any input I get on this.
-Brian
  • 92 Firebird sold
  • 97 Talon TSI AWD sold
  • 05 Cobalt LS sold
  • 02 Tahoe LT sold
  • 06 Cadillac STS4 AWD sold
  • 03 Corvette Z06
  • 14 Silverado 1500
Old 04-08-2006, 10:56 PM
blk_srt's Avatar
blk_srt blk_srt is offline
Send a message via AIM to blk_srt Send a message via MSN to blk_srt
Re: 6 Bolt vs 7 Bolt
the 8.5: compression of the 2gs seem to be the basis for most turbo applications, low enough to run as much boost as you want but high enough for a decent low end. As far as the heads go, the 2g has a more efficent design but the 1g will flow more air. Its impossible to port a 2g out even to match a stock 1g so as far as the head I would go with a 1g no matter what. Oh and the cam/crank sensor, I dont see why you cant use your stock units.
2004 Flame Red SRT-4
|Audiobahn 1200Q|Rockford 602s|Jensen flip out dvd|
Mods:
Old 04-08-2006, 11:31 PM
Talon69's Avatar
Talon69 Talon69 is offline
Send a message via AIM to Talon69 Send a message via MSN to Talon69 Send a message via Yahoo to Talon69
The crankwalk is coming from inferior cranks. They are only hardened like 2 Thousandths thick. The thrust washers are actually chewing into the cranks.
Here check this out man, this guy goes threw a 6 hour hardening process on the crank. Call him he will be happy to talk to a future costumer, he knows his shit!!
http://www.overbore.com/
Just enter site and you will see 7 bolt crankwalk fix
Current Cars
2006 Eclipse GT 6 speed MT (V6 3.8), mods so far- S Tech Springs, after market 18's, 2012 headlight Conversion, Greddy cat back exhaust, CAI, RRE Headers, Polyurethane Motor Mounts, NX Nitrous kit at 100 shot for now, RPM Window Switch, Triple Pod.
2003 Grand AM GT - official beater car for the winter lol
95 TSI AWD [email protected] (T-25)
Now fully Modded engine with 3,560 miles on it.SOLD
Old 04-08-2006, 11:33 PM
blk_srt's Avatar
What are we supposed to check out? To me it doesnt make any sense that the bearing would "chew" into the crank. I dont get how that would cause excessive end play
Mods:
Old 04-08-2006, 11:35 PM
Talon69's Avatar
I read online somewhere that if you can get your 2g head ported out it would kick the shit out of the 1g head. People have ported there 2g out. I will have to do some search to find link but if i can find it again i will post.
Current Cars
Old 04-08-2006, 11:37 PM
blk_srt's Avatar
My 2g head is ported I'm sure you can get a 2g head to flow better than a stock 1g head but it is impossible to get the runners on the 2g to match up to a stock 1g let alone a ported 1g so I think that a 1g would be a better option because with porting a 2g couldnt touch it.
Mods:
Think about it... When the clutch is pushing on the crank and the bearings are in place, the crank is actually putting pressure on the passenger side of the bearings... I'm sure with enough of that on cheaply manufactured cranks will cause the sharp edges of the bearings to start to wear into the crank and then the crank gets that little bit of play in it. So it wouldn't necessarily be thrust bearing failure, but cheap crank failure which would appear to be the result of bad bearings. Did I explain that correct Talon69?
-Brian
  • 92 Firebird sold
  • 05 Cobalt LS sold
  • 02 Tahoe LT sold
  • 03 Corvette Z06
  • 14 Silverado 1500
Old 04-08-2006, 11:38 PM
Talon69's Avatar
The bearings are harder than the crank, so when the bearing wears into the crank you get excessive end play. Call this guy that i listed in above. He is in big import magezines and he his also the #1 4g63 machine shop on the east coast. Just call him and talk to him i cannot sit here and vouch for him. I met him in person at a import show. He knows his shit.
Current Cars
Old 04-08-2006, 11:40 PM
Thats why you get an aftermarket intake manifold too.
-Brian
  • 92 Firebird sold
  • 05 Cobalt LS sold
  • 02 Tahoe LT sold
  • 03 Corvette Z06
  • 14 Silverado 1500
Old 04-08-2006, 11:41 PM
Talon69's Avatar
When i took my engine apart i had some where in the crank. When i got my new bearings i measured them to the old ones. They were almost the same.
Im not saying i know what the cure is im just saying what this guy says about solving the prob.
Current Cars
Old 04-08-2006, 11:43 PM
blk_srt's Avatar
What I'm saying is that if you compair the runners on the 2g head to the runners on the 1g head you will see that the 2h head has litterally half of the size runners as the 1g head has and there isnt enough material on the 2g head to port match the head to a 1g intake manifold. Here look at this http://www.vfaq.com/mods/1G-2G_intake.html that compairs them to each other
Mods:
Old 04-08-2006, 11:51 PM
Eagalicious's Avatar
Eagalicious Eagalicious is offline
I am lost.
Eagalicious's
1997 Eagle Talon Tsi AWD
K&N FIPK
3rd gen lifters, installed
Apexi Turbo Timer w/harness!!! now to install
Eibach Springs coming soon
3" turbo back with straight pipe.
The muffler was the wrong one
Manual BC
1G BoV
The rest is stock but not for LONG!!
Old 04-08-2006, 11:59 PM
Yes I see how much different they are. But what you could do is port it out as much as possible and then get an aftermarket intake, cut off the flange, have the runners taper down some to match it and then make your own flange. The only advantage to having it taper slightly is that it'll speed up the air speed going into the head. Its a full proof plan.
I think.
-Brian
  • 92 Firebird sold
  • 05 Cobalt LS sold
  • 02 Tahoe LT sold
  • 03 Corvette Z06
  • 14 Silverado 1500
Old 04-09-2006, 12:11 AM
blk_srt's Avatar
I still really think that you could port out a 1g head to be WAY better than any 2g head you could get. I had a discussion with kevin about this a while back. http://www.automotiveforums.com/vbul...ght=1g+head+2g there is the link
Mods:
Old 04-09-2006, 12:32 AM
clipsekid99's Avatar
clipsekid99 clipsekid99 is offline
Send a message via AIM to clipsekid99 Send a message via MSN to clipsekid99
Ehhh where's Kevin when you need him? lol
2006 Wicked White Evo IX GSR
323 awhp / 311 tq. (Dynojet)
http://www.projectevoix.com
http://www.4WStuning.com
99 RS < 98 GSX < 06 EVO
