Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 04-08-2006, 07:36 PM
wanaplay134 wanaplay134 is offline
Send a message via AIM to wanaplay134
Red face suspension help PLEASE
i have a 92 talon tsi. i have this noise coming from the passenger front and it sounds terrible. so i figure it is the wheel bearing. i just ordered and have 2 new wheel bearings. so today i needed to do my egr block off and put a downpipe gasket so i figured shake the wheel see whats up, anyways the wheel moves up and down like a couple inches at least its bad, now my ball joints and tie rods all have maybe 50 miles on them so it cant be that, does anyone think its the wheel bearing being broke out or something i have no idea what it is any help would be good.
1992 eagle talon tsi awd
xtd stage 3 six puck/apexi 3' downpipe and exhaust/ngk plugs/taylor thunderbolt wires/manual boost controller set at 20psi/walbro 255 with rewire/autometer boost gauge/turbo xs rfl blow off valve/arp headstuds/ to4b vtrim turbo/dnp tubular manifold with o2 housing and tial 38mm wastegate/eagle rods/ross pistons/acl bearings/arp rod bolts/arp main studs/aeromotive fuel pressure regulator and all stainless lines/aem fuel rail/slowboy street front mount kit
Old 04-08-2006, 07:46 PM
Blackcrow64's Avatar
Blackcrow64 Blackcrow64 is offline
Re: suspension help PLEASE
Sounds like the balljoint to me... Only other possibility would be something is very loose or unbolted. A couple inches of play is definetly something to worry about but I wouldn't think the wheel bearing would allow it to move that much. The wheel would have fallen off way before letting it move a couple inches like that.
-Brian
  • 92 Firebird sold
  • 97 Talon TSI AWD sold
  • 05 Cobalt LS sold
  • 02 Tahoe LT sold
  • 06 Cadillac STS4 AWD sold
  • 03 Corvette Z06 sold
  • 14 Silverado 1500
  • 26 Equinox RS
Old 04-08-2006, 07:49 PM
blk_srt's Avatar
blk_srt blk_srt is offline
Send a message via AIM to blk_srt Send a message via MSN to blk_srt
is it the knuckle or the hub that moves?
2004 Flame Red SRT-4
|Audiobahn 1200Q|Rockford 602s|Jensen flip out dvd|
Mods:
Old 04-08-2006, 10:20 PM
i dont know what is moving really yet i didnt get that good of a look. i turned the wheel away from the car and checked the ball joint and tie rod and they are solid as a rock no movement at all which it should be they are brand new. when i shake the wheel all i can see is the whole rotor and all is moving like its not attached or something. maybe the hub is loose or something im not sure im going to rip it down tommorrow.
Old 04-08-2006, 10:23 PM
blk_srt's Avatar
you can check the wheel bearing by lifting the tire in question in the air and turning the wheel and hold the spring and feel for roughness
Mods:
