Go Back   Automotive Forums Car Chat > Dodge > Daytona
Old 04-08-2006, 06:52 PM
KronzniK KronzniK is offline
turbo engine into a nonturbo help....
i have purchased a 89 daytona and i am takin the engine out of a daytona 87 but the engine was in a 88 shadow origanily and were noticing some diferences in the wiring and its lookin like this 2.5 had a whole lot less vacuum lines then my engin has hooked to it..... any help to help my tackle this vucuum and wiring on this engine swap would be most appreciated thnx dodge enth. much appreciated
Old 04-08-2006, 07:22 PM
Arrow Re: turbo engine into a nonturbo help....
apon some other lookin i think we can make the vacuum work but our main concern is power for the fuel injection....and if this makes a diff the daytona had a message center from factory.any info would help once again thnx:P the distributer on the turbo has 2 wires off it unlikethe non turbo wa=hat can i do about that.....
Old 04-15-2006, 12:33 PM
AWP9521 AWP9521 is offline
Your in for a big job to swap that and make it work, wiring and engine controllers are way different between those years, the later models had the single engine controller under the hood instead of the earlier models separate logic/power modules for engine management. Also the non turbo engines were usually throttle body injected where the turbo engines were multi-point injected which opens yet another can of worms.
If the car has the turbo engine in it then you would be better off staying with a turbo engine to replace it or vice versa, a lot less headaches to work with.
Originally Posted by AWP9521 - 02/16/2005
Sure sex is a thrill too, but your modified car will never tell you
"Sorry honey, I just don't feel like it tonight" it will always be in
the garage silently waiting for you to hop in so it can thrill you
some more, that is unless you break it. At least they're easier
to repair and get the thrill back than a pissed off girlfriend.
