Go Back   Automotive Forums Car Chat > Nissan > 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX > Technical
Technical Discuss Engine, Suspension, Drivetrain, and all other technical issues here.
Old 04-08-2006, 12:35 PM
RedRain's Avatar
RedRain RedRain is offline
Send a message via AIM to RedRain Send a message via MSN to RedRain
Suspension
I'm having hellish wheel hop. I have put some of those metal bushings in the rear. Should I be looking for broken parts?
81 N/A 280zx-KIA
83 Turbo 280zx-KIA
91 240sx-In Limp Mode
Old 04-08-2006, 01:03 PM
sidewayzS13's Avatar
sidewayzS13 sidewayzS13 is offline
doin it sidewayz
Send a message via AIM to sidewayzS13
Re: Suspension
new motor and tranny mounts should help i suggest nismo.
Originally Posted by Muscletang
I say let it run its course. Most women experiment with things. They'll try something whether it's mind altering drugs, going down on their best friend, an Emo song, or plastic surgery.
Old 04-08-2006, 01:06 PM
David_NISMO David_NISMO is offline
Re: Suspension
Wheel hop in a 240? Never seen it before. Doesn't sound like somethings right there.
Describe the "wheel hop"
Rolling in a power by a
Old 04-08-2006, 01:09 PM
doin it sidewayz
Re: Suspension
i usd to get wheel hop when i first got my sr and had the old motor mounts and when i put in the nismos it was gone
Old 04-08-2006, 07:54 PM
Skylindrftr Skylindrftr is offline
Send a message via AIM to Skylindrftr
Re: Suspension
It was raining the other day so i went down to the rosebowl to mess around, instead of oversteering, most the time my car had wheel hop =( any ideas?
Im guessing its b/c I run super sticky tires in back and crap up front?
Old 04-08-2006, 08:35 PM
doin it sidewayz
Re: Suspension
if ur drifting and shit run the stickys in the front. as far as the wheel hop goes though it could just be bad suspension for the coditions you were pushing your car whats the suspension set up?
Old 04-08-2006, 10:34 PM
RedRain's Avatar
Re: Suspension
Its wheel hop. Ever been to the drag strip and watched a car loose traction and the rear tires bounce? Also going around a turn to fast will give me wheel hop.
All of it is stock except those bushing I put in. I have been under the car looking for broken parts I have not seen anything that looks out of place though. It hops with any loss of traction. Think I'm going to get some of those traction rods and see how that helps. Any sugestions on what I should do 1st? My main goal is quarter mile times.
81 N/A 280zx-KIA
83 Turbo 280zx-KIA
Old 04-09-2006, 10:49 AM
doin it sidewayz
Re: Suspension
i still say motor tranny mounts. where did u get the bushings from are they the actualy bushing or just the easy install inserts?
Old 04-09-2006, 08:44 PM
slideways...'s Avatar
slideways... slideways... is offline
Re: Suspension
motor mounts, subframe bushings, if it still persists, id say your suspension is less than ideal(read: get coilovers)
Rice Police #1. dont argue with me just because you are a riceboy and/or have sand in your vagina. i am superior. and i am smarter than you. end of story.
Old 04-09-2006, 09:53 PM
nissan_240sx nissan_240sx is offline
Re: Suspension
I get wheel hop when I stand burn long and the tires get sticky. It's like the back tires want jump over the front tires lol. oh well two 215/45/R17 michelin pilot sports getting sticky lol
-Matt
NISMO
1992 240sx SE Fastback 5speed
Old 04-10-2006, 06:13 PM
Re: Suspension
i think im just running too hard a setup, this was in the rain in the rosebowl parking lot, Full Tein HR Coilovers 1 degree of neg camber up front, 205 goodyear eagle t/a worn half way up front (15 inch), on back pretty new 16 in bridgestone potenza re750 245, I am also running a stiffer rear, open diff and strut bars front and back...
I know it sounds screwed up but what could cause the wheel hop?
Old 04-11-2006, 01:50 AM
Re: Suspension
again, id point to motor/tranny mounts or subframe bushings
also, if your suspension is too hard and your running like 45 series tires, the big sidewalls could sort of become part of the suspension and add flex and soften the spring rate down by the contact patch.
but most likely, the flex and movement in the mounts and subframe is probably the thing causing the suspension to hop separate from the car.
or i doubt this is it, but if your shocks are old, your compression rate couldve fallen some, and it could mean its time for a rebuild, but i think youd be able to tell when you drive around also...
Old 04-11-2006, 02:04 AM
Re: Suspension
I would agree. I could see stiff coilovers conflicting with gushy, soft, stock rubber bushings and cause wheel hop.
Old 04-11-2006, 05:48 PM
Re: Suspension
Doh I really dont wanna replace bushings, my freind did it to his 240 (he is good at that kind of stuff) and it even took him a lot of time and frustration etc...
Old 04-12-2006, 05:43 PM
doin it sidewayz
Re: Suspension
yep bushings are a bitch but sack it up
