Go Back   Automotive Forums Car Chat > Dodge > Dakota
Old 04-08-2006, 11:43 AM
Bassman2006 Bassman2006 is offline
Thumbs down Parking, Tail, and dash lights
I have 93 Dakota. Lost my parking, tail, and dash lights. Manual says check fuse #8 on fuse panel since they are all on the same circuit. It was fine. I checked all my grounds (that I could find) and they are all ok. Local parts house says its the light switch is the most likely culprit. Is there something else that could cause that circuit to not work?
Old 04-08-2006, 11:54 AM
dirty hands's Avatar
dirty hands dirty hands is offline
Send a message via Yahoo to dirty hands
Re: Parking, Tail, and dash lights
if you have done all that diagnosis and still no lights
It has to be the switch
can you unplug the wiring loom and get power to the circuit to check the lights with a length of wire from the battery terminal ?
thats the last way of checking the lights
Old 04-08-2006, 12:52 PM
Stevo2's Avatar
Stevo2 Stevo2 is offline
Do the horn and stop lamps work ok?
Check fuse #13 also.
Both of these circuits are fed off of the headlight switch, you might want to check the connector on the switch to see if it's melted.
Jack of all trades...Master of none!
Could someone please fix my Instant Email Notification?
Please get back to us with your fix!
Why did you buy a $40K vehicle and not a $100 Factory Service Manual?
Old 04-09-2006, 05:27 PM
Jon Teeter Jon Teeter is offline
You may also have a short.If you have a trailer hook up check and make sure there are no bare wires touching.
