Go Back   Automotive Forums Car Chat > Dodge > Dakota
Old 04-08-2006, 10:59 AM
95cavspeed's Avatar
95cavspeed 95cavspeed is offline
Smile 92 Dakota Need Help!!!fuel Problem
hi,i Have A 1992 Dodge Dakota Club Cab 3.9l V6 5 Speed,
my Fuel Pump Went When I Ran It Low On Gas,i Changed It With A Used Fuel Pump,then That One Lasted Bout 2 Days And I Had $20
worth Of Gas When That One Went,i Hear Something Clickin Back By The Gas Tank Did Something Go Bad,like A Relay Unit In The Back, Or Get Another Fuel Pump,new This Time? I Dunno
Old 04-08-2006, 12:36 PM
Stevo2's Avatar
Stevo2 Stevo2 is offline
Re: 92 Dakota Need Help!!!fuel Problem
Are you sure the pump is actually bad?
Can you hear the pump run for 2-3 seconds when you trun the key to "on"?
You may have a bad cam or crank position sensor, if so this would cut off the power to the fuel and ignition by shutting down the ASD relay.
Jack of all trades...Master of none!
Could someone please fix my Instant Email Notification?
Please get back to us with your fix!
Why did you buy a $40K vehicle and not a $100 Factory Service Manual?
Old 04-08-2006, 01:18 PM
95cavspeed's Avatar
no its not coming on,this is the second one thats burned out
it came out of a dakota with 183,000 miles and it was sitting for a year but the gas was fine and there was no deposits on the fuel pump and it ran fine,
the motor runs great so maybe the crank sensor but i dunno it,after the first one went i put this one in and everthing seemed fine.
Old 04-08-2006, 01:36 PM
Stevo2's Avatar
That's too many miles for a used pump...go with a new one but not from Autozone unless you want to replace it every month again. I recommend trying an onlin Dodge dealer like www.makeitmopar.com it looks like they sell the complete module for $191 plus shipping..Autozone gets $160 for their junk, so it's worth the extra bucks to get the original.
Old 04-10-2006, 08:18 AM
95cavspeed's Avatar
ok well heres the deal,i let the truck sit overnight and the fuel pump was working i drove it for bout 30 minutes,then shut it off and the fuel pump doesnt come on?
Old 04-10-2006, 12:34 PM
95cavspeed's Avatar
ok heres the deal both fuel pumps are bad i took them out and tested them they come on for a quick sec and die out?is there something that is burning these out ?i guess i need a new one but i would like to make sure the third one doesnt die,thanks
Old 04-12-2006, 12:21 AM
Stevo2's Avatar
Time for a brand new fuel pump module with the in tank strainer, you must also replace any inline fuel filter to make sure bits and pieces of the old pump are not in it. If you have junk from the old pump in the inline filter the excessive backpressure will fry the new pump. Also flush the gas tank.
Old 06-20-2007, 05:18 PM
WarHawk1974 WarHawk1974 is offline
I have the same problem..however I get good spark, can dump a bit of fuel in the throttlebody and it will fire right up, but cant hear the fuel pump whine when to pre-pressurize the fuel line, I know the fuel pump works
When the truck cools down, it will randomly whine when I flip the key switch, other times it wont
Can the fuel relay get old or go bad after time? I have switched relays out in the box in the engine well...but it still wont work, sometimes it does, sometimes it wont, but once it works it works fine and will stay running no problems
Oh yah..I have a '92 Dakota with the 5.2L 318V8
