Old 04-08-2006, 12:09 AM
chili chili is offline
Fluid Question
Hey all I have a '90 Cherokee 4.0L 4x4 and I am wondering what the CORRECT fluids are for the powersteering and the transmission ? Getting ready to do a little maintenance and I want to get the right stuff.....
Old 04-08-2006, 10:42 AM
Repo_agent Repo_agent is offline
Re: Fluid Question
Power steering fluid and transmission fluid.
ATF will be marked big on the tranny fluid. Just read the back of the bottle it will tell you. Dexron Mercon 3 isnt what you want.
Power sterring fluid is basically all the same I would think unless they have synthetic.
Old 04-08-2006, 04:35 PM
nascarmechanic nascarmechanic is offline
Send a message via AIM to nascarmechanic Send a message via MSN to nascarmechanic Send a message via Yahoo to nascarmechanic
Re: Fluid Question
The transmission takes ATF+3 and it is NOT THE SAME as regular ATF. The fluid is also known as 7176 Chrysler transmission fluid.
The Power steering can be either Dexron 3 transmission fluid or the regular labeled power steering fluid found at your local parts store
Old 04-08-2006, 05:25 PM
JDPascal JDPascal is offline
Re: Fluid Question
According to the FSM, the correct fluid for the AW4 automatic transmission is a Dexron II compatible fluid. That could be a Mercon/Dexron III type or use the Mobil1 or amsoil synthetic both are fine for that tranny. The AW4 transmission is the one with the dipstick attached to the side of the pan.
If you have a manual trany, go with a synthetic 75w90 gear oil.
I'm not into Amsoil or anything but their website has a fluid selector guide for any vehicle.....http://www.amsoil.com/scripts/runisa...msoiloaf:index
Their ATF recommend is their product which is good for any vehicle so It won't be specific enough if you use a non synthetic ATF
The fluid used for the power steering is power steering fluid According to the FSM. Dont mix ATF in the power steering (unless you are stuck).
Just use a turkey baster to suck out all you can and top it up. do this for about 3 weekends in a row and you'll be fine. Don't undo steering lines or you'll have no end of trouble with air in the system. Even an experienced person can pull their hair out over that kind of trouble.....
JD
If ya can't fix it right the first time, how ya goin ta find the time ta fix it again????
Old 04-08-2006, 05:32 PM
Ray H Ray H is offline
Re: Fluid Question
As stated above, ihe proper fluid for the AW4 is Mercon/Dexron III, not ATF 3. The ATF 3 is used in Chrysler auto trannies but the AW4 is not a Chrysler tranny, its a Japanese tranny.
Old 04-09-2006, 01:26 AM
sklater sklater is offline
Send a message via MSN to sklater
Re: Fluid Question
also, you might want to go to the dealer where they can look up your vin to verify what fluid to use. I was told to use a mopar atf+3 for my tranny, but when I went to the dealer they looked it up and found i needed a dexron 3 instead. Hopefully it helps.
jeff
